Question about Nokia Cell Phones
Unlock code for Nokia 2320c-2b - Type RM-515 IMEI:
Unlock code for Nokia 2320c-2b - Type RM-515 IMEI: 011974003661512
  • 1 more comment
  • mnf9 Aug 03, 2010
    I need to use this ATT phone on a another network, but the phone will not accept the SIM-card. Can anyone provide the code to unlock the phone, so it will accept SIM-cards from other network-operator? Thanks
  • mnf9 Aug 03, 2010
    Hi there!
    Can you help with a 10 digit? unlock code for a ATT-locked Nokia 2320c-2b with EMEI: 011974003661512?
    I would like to use the phone on another network.
    Thanks
  • mnf9 Aug 03, 2010
    Network unlock code for prepaid Nokia 2320 needed...
    Genius:
  • 1,478 Answers
You can get the unlock code by contacting your current service provider customer care department. If your phone is locked you can use any of your friends phone to make this call. The service provider will then provide you the unlocking codes.
Remember that the reason why the codes are provided only through customer service provider is that, they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.
This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides unlock codes. All are fake. Only your service provider can provide these codes.
Another alternative is, you can take the phone to any authorize phone service center to help unlock the phone, because to unlock your phone, you will need some kind of software, USB cable etc to unlock the phone, so you can also go a nearby phone service center to unlock the phone, but calling your network service provider is the best because they have the records of your phone and can easily help to unlock it. This are the two reliable means you can unlock your phone.
Posted on Aug 04, 2010
  • 5,081 Answers
As you have not specified which code you need i am hereby giving how to get all of the codes:
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer caredepartment.It is free of cost.
Therestrictioncodecan be got from your old service provider..This restriction code iskeptto prevent someone who stole themobile from using it withanotherprovider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost donot pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above proceudre works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
Posted on Aug 03, 2010
  • 3 more comments
  • INDIRA KUMAR
    INDIRA KUMAR Aug 03, 2010
    You are asking for an network unlock code:
    http://hubpages.com/hub/How-to-Flash-you...
    http://www.fixya.com/support/t4035818-ne...
  • mnf9 Aug 03, 2010
    Hi. Thanks for your input.
    I do not have a data cable for the phone so flashing is not an option.
    I guess the operators implement Network restriction codes to avoid customers using their newly purchased (and discounted) with another provider ;-)
    The challenge is that this is a prepaid GoPhone, so I have no registration with ATT.
    I hoped to find someone with a NUC-code generation tool for this type of phone...?
  • INDIRA KUMAR
    No we donot have such tool and sorry such generation of code without proper authorisation is illegal.
  • mnf9 Aug 03, 2010
    No problem. I will try to contact ATT for a code.
  • INDIRA KUMAR
    INDIRA KUMAR Aug 04, 2010
    Please reconsider the rating you have given...
  • Nokia Master
  • 4,737 Answers
What unlock code do you want? Network unlock code or phone unlock code or sim unlock code? Since your question isn't so specific, i can't assume myself.
I hope you've tried with the default code 12345, if not do it.
Awaiting.
(This isn't a solution yet, only a clarification)
Thanks.
  • 3 more comments
  • mnf9 Aug 03, 2010
    I need the code to remove the current lock that prevents the phone from accepting non-AT
  • mnf9 Aug 03, 2010
    My previous comment was truncated... I need the code to remove the current lock that prevents the phone from accepting non-ATT sim-cards.
  • Lebanon Raingam
    Lebanon Raingam Aug 03, 2010
    Actually, unlocking the Network Lock is not so simple as unlocking phone lock or security lock (note: in your case, both sim lock and network lock are implemented, so once the network is unlocked, sim lock will also be unlocked as well).
    You have only a couple of options without contacting the Service provider, (in your case ATT). But this are the tricks with formating your phone, not with just the lock. First try this, backup or save all the contacts and important messages or notes, now on the main screen type in *#7730# and follow the onscreen instructions with positive inputs, if you are asked to enter a new code or confirmation code, enter 12345. I can't assure if this will work or not, but for most models this can easily fix the lock if there's no other third party software installed.
    If unfortunately the above code doesn't work, try with this *#7780#.
    You can also try formatting it with the key combination trick. Turn off the handset, leave it off for few minutes, now press * + 3 + Green/call key + Power switch simultaneously. Keep pressing before you see the prompts on the screen, and follow the onscreen instructions, may take few minutes formatting, but you need to be patience or else, you may damage it. (note: everything saved on your phone memory like contacts, messages etc.. will be deleted automatically).
    There's another simpler method, if you can call the customer of the service provider, do it and ask them the unlock code for your phone, but for this your AT sim card/Network should be active and the one you make calls should be itself, otherwise they'll not entertain your call.
    Good luck.
    Thanks for using FixYa.
  • mnf9 Aug 03, 2010
    Thanks for your input. I have already tried to reset the device. I have no access to ATT network since I am back in Denmark. I need a 10-digit unlock code to remove the ATT restriction.
  • Lebanon Raingam
    Well, if you have tried all the unlocking and formatting methods that i've mentioned, your only option is to get it unlocked from a Nokia Service Center or from any nokia repairing shop. There's no other solution I know of. They may charge you $1 to $10, (rate varies), but will take less than a 5 minutes to get it done. Once it's unlocked from them, you'll be able to use the handset with any network, there'll be no more restrictions.
    I wish you good luck.
    Once again thanks for using FixYa.
Unlock code for rm-515
Hi if your Nokia 2320c mobile is locked to network provider .Then you can easily unlock it using sites like MobileUnlockSolutions.com they are providing unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone .
Apr 04, 2014 | Nokia 2320 Cell Phone
How to unlock nokia 2320c-2b AT&T mobile , please give me restriction code
Help me pls .. Emei 011975/00/160746/4 rm515 code 0579480q174r nokia 2320c-2b help unlock please
Dec 11, 2011 | AT&T Cell Phones
Please !!! restriction code for my nokia 2320c-2b from usa( at&t) RM-515 imei: 012185000863485
You can get the restriction code from your network provider or you may get it from online providers like Prounlocking.com . They will help you to unlock your mobile easily..
May 14, 2011 | Nokia 2320 Cell Phone
PLesae send me the nlocking code with instruction for:
nokia 2320c-2b
phone type- RIM-515
unlock code please imei:011974/00/068426/9
code: 0579480KQ204S
. email:abhimeri@gmail.com
Thanks in Vance.
Jun 06, 2010 | Nokia 2320 Cell Phone
Need unlock code for Nokia 2320c-2b
May 07, 2010 | Nokia 2320 Cell Phone
Looking for the unlock code for a Nokia 2320c-2b. IMEI: 011975000417279 Provider: AT&T Type: RM-515
For information on unlocking the cell phone, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then this WEB site provides security codes for a small price.
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
Feb 14, 2010 | Nokia Cell Phones
Unlock code for Nokia 2320c-2b IME:011974000658867
my nokia 2320c-2b is showing restriction code.
please any one help me.
Jan 09, 2010 | Cell Phones
Cell Phones Logo
626 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
