Question about Master Lock 5400d: Portable Select Access Key Storage Lock
I have one of those circular master locks, but i forgot my combination, i panicked so i tried to bust it open with a hammer now its busted up, closed, and there is no dial on it, what do i do?
    Brigadier General:
  • 3,006 Answers
You'll have to complete the destruction job and cut off the lock or drill into it. As the lock is designed to resist these attacks it may be cheaper and quicker to call in a locksmith who will have the skills, tools and experience to do the job safely.
Usually I'd advise the use of a bolt-cropper, but the shape of your lock makes applying one very difficult.
There is a cheap option which may work but is trickier than YouTube videos make it look: use a shim on the lock shank. Just search for "lock shim" and you'll see examples of how to do it. Trying it costs almost nothing and so it's the first thing I recommend that you try.
Good luck and please take a moment to rate my answer.
Posted on Aug 03, 2010
Can not open with combation don,t have key for safe
You will have to bust it open
try dropping it ******* conor or hammer and chisel. you can not pick the lock
Sorry only way is to wreck safe.
I just opened a bunch at estate with no key or combo
Hope this helps Mike
Feb 07, 2016 | Sentry Fire-Safe Media File - SEN6720
How to open sentry valueguard safe 1330 1744403
I do not claim to be an expert, however I recently opened a valueguard 1330 that had been sitting at work abandoned and forgotten for sometime. I used simple hand tools for this, this method is crude but it worked. The underside of the safe has a plug in it which is where the factory fills the safe with an insulation that sets and hardens giving structure and weight. I imagine there is a better way to remove the insulation but at this time i used a hammer. It looks much the same as chalk with a harder consistency, a minute or two of hammering broke up most of it which was then cleared out by hand. underneath is a plastic liner and the inner floor of the safe. Once again I just had hand tools at the time, I used a hammer and punch to perforate the steel in a circular pattern. once this was finished a few solid strikes should be enough to bust through. Please keep in mind a drill would have been optimal, also the hole needs to be large enough for you to put you arm in. On the inside portion of the door there is a cover over the lock assembly held in by one screw, on this safe it was a combination flat head 1/4" drive screw. With the cover plate removed you should now be able to see three plates on a central axis, each plate has a slot that needs to alined with the lock assembly for it to travel. This is incredibly easy when working by feel alone. With all three alined you should be able to turn the handle on the outside counter clockwise and open your safe. I hope this helps anyone not wanting to pay a locksmith or sentry, your safe should still be viable except for the arm sized hole. I would suggest a new safe. Enjoy!
Jan 16, 2012 | Sentry Safe Qe4531 Firesafe Waterresistant...
How do you open a master lock model 5400d if you forgot the combination
It would appear that you made a mistake in setting your new combination on your Master Lock 5400d and did not register the combination at Masterlockvault.com. The only way to open your lock is by using the correct combination. There is no other way. Most mistakes are normally one or two digits out, so you may wish to try variations on what you thought you set.
Apart from that you can either try every possible combination or you will need to contact the manufacturer. But they cannot assist you if the lock does not have a serial number (they recently stopped applying serial numbers for greater security) and they will not assist if the lock is already secured to anything. There are a number of other hurdles as well, click here for details. Given that they state that you will have to wait four to six weeks for an answer, it's going to be far quicker to just try every possible combination.
Jul 14, 2011 | Master Lock 5400d: Portable Select Access...
I forgot the combination to my master lock box. What do I need to open the box?
If you do not have the combination, try to contact the manufacturer directly. There may be a serial number on the lock that they can match the combination to.
If that does not work, you will need to contact a locksmith.
Apr 20, 2011 | Master Lock : Locking Combination 5-Key...
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
2001 Grand Am Trunk will not open, button or key any ideas?
Since you've busted the trunk lock.Look thru the lock hole and you will see a slot in the lock with a metal shaft thru it.Use a flashlight.Place a flat blade screwdriver in this slot and turn it clockwise to unlatch
Sep 30, 2009 | 1995 Toyota Camry
I got the master lock speed dial and forgot my combination
Try your old password but push the shackle towards the lock once then put in your old password twice then pull the shackle
Sep 16, 2009 | Master Lock 5400d: Portable Select Access...
Forgot my combination to my sansomite suitecase
a local lock smith can help but by now you have busted the hasp
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 07, 2007 | Impact 800 Tripod
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
190 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
