My Brother copier printer DCP-IIOC, will copy but won't print, in fact the computer won't recognise the printer, the usb cable is fine, what is wrong or can you help me please?
  • 19,396 Answers
Try this :
First check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Posted on Apr 25, 2008
What Print unable 0B
brother dpc 1510 printer showing on print unable 0B. how to clear?
May 27, 2016 | Brother DCP-1510 Laser Multifunction...
Brother 1510 replace toner problem
Assuming you have tried to replace an empty toner with a new or refilled toner cartridge. Some of these machine simply fail to recognise the reset activation lever on the side of the cartridge. You could try removing the end cap at the geared end. You will find a half moon shaped gear which needs to be lifted out slightly and rotated a quarter turn clockwise. replace any other gears and refit the cover. This resets the toner cartridge to "new" state. If you printer doesn't recognise this, you will need to get a manual reset keycode from brother. Please note - some folk reset used cartridges this way and re-use them. Used toner will contaminate the drum and give poor print. Any residual contaminated toner on the drum can contaminate a new cartridge and so-on. Refilled cartridges are fine if the cartridge is completely cleaned out first.
May 06, 2015 | Brother DCP-1510 Laser Multifunction...
Brother printer will not recognise usb cable I can load printer onto laptop through usb cable now want to load onto dell pentium 4 and keeps coming up does not recognise usb cable so keeps asking you to...
Try a new cable and a different USB port. It's possible dirt is making for a bad connection or that the cable is slightly damaged and this other computer is more sensitive to the problem.
I hope this helps.
(who has dealt with a damaged USB cable that didn't look bad and gave an intermittent problem with one computer and associated hardware.)
Apr 10, 2010 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 8045D prints and copies but won't scan
Check out that the Scanner USB cable is connected to the PC apart from the printer Cable
Mar 08, 2010 | Brother DCP-8045D (Bundle) All-In-One...
Lost the instaling cd for my brother dcp 135c
You can download drivers and software from brother website.
Download driver first.
Unplug printer usb before installing driver software, and start installation with printer usb cable unplugged.
Here the download page: Brother Software Download
Apr 19, 2009 | Brother DCP-135C Flatbed Digital MFC...
Brother DCP-130C Printer.. not Printing.... When i give command from computer
try to reinstall the usb drivers. Delete before by help of the agressive remover which is part of the install cd (you have to open the cd).
Connect printer directly to usb of pc . DO NOT use a hub.
hope it helps
Mar 03, 2008 | Brother DCP 130C All-In-One InkJet Printer
56 people viewed this question
jasbo
jasbo
