Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Smartwater GE50T06TAG Water heater - General Electric GE SmartWater Household Water Filtration System - GNWH38F
4 Suggested Answers
  • 608 Answers
SOURCE: I have a 80 gallon Ge smartwater hot water heater
Normally no, but for a circuit breaker to activate, there has to be excessive current draw somewhere. Is the circuit breaker exclusive to the water heater? If it is then the heating element may have shoirted internaly. Fit a new element and restest. Don't forget to check the condition of your sacrifical annode too.
Posted on Mar 19, 2010
  • 102 Answers
I know an element can cause the breaker to trip. But I dont know about over heating. That sounds like a wiring issue. I would contact an electrician. Hope this helps.
Posted on May 14, 2010
  • 5245 Answers
SOURCE: not enough hot water ge smartwater water heater gas
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Feb 20, 2013
Not enough hot water ge smartwater water heater gas
Feb 19, 2013 | General Electric GE SmartWater Household...
GE Profile SmartWater Heater #PG50T9XA
1) Copy following link:
http://waterheatertimer.org/Low-hot-water-pressure.html
2) Add comment and say what you find
Dec 28, 2012 | General Electric GE SmartWater Household...
I have a GG40T06/487-246 GE SmartWater Water Heater, it is about 10 years old and now there is leak on the position of the stem of the reset button connecting to the gas valve. Any suggestions to replace...
A 10 year old water heater is at the end of its life expectancy. No sense replacing a gas valve to have the tank rust out next month. I'ld replace the whole unit. Also, install a drip pan, under it and a WAGS safety device. Any water in the pan and the WAGS will shut off he Water and Gas. If your water heater has an expansion tank near by, replace that too.
Jul 19, 2010 | General Electric GE SmartWater Household...
GE Smartwater Heater model# GG40T6A won't stay lit
Look and see if your pilots flame is touching the themocoupling ,if it isnt then cleane your pilot orfice.If that dosnt work replace thethermocoupler.I would also check the draw. Hold alit match or a cigerett up to the draft diverter (the air space between your heater and the vent. If it dosent draw the smoke up the vent it meanes your vent is stoped up or you need to raise it.
Dec 02, 2009 | General Electric GE SmartWater Household...
My GE smartwater hot water heater has no pressure. what are some troubleshooting thing i can try?
try to open and close the valve at the unit,this shut off valve may have gone bad,replace it this may help.
Jul 29, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater heater problem
most units from GE come with a 3 year manufactures warantee and the home depot should have no probleme giving you a new one off the shelf with your receipt they will send it back and get there money back from GE so they pass it on to you. it would cost you the same amount to fix that one then to buy a new but yours is still under warantee untill july. hope it works out for you.
Jan 04, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
176 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
