Question about Dishwashers
It has been awhile since my dishwasher has been cleaned and someone told me about filters and stuff. Is there anything I can do or buy that will clean out all the gunk and stuff from the dishwasher arrms and filters and things?
  • 171 Answers
You can try and run 1 cup white vinegar through a cycle.  if that doesn't do it, you can purchase a product called "Dishwasher Magic" available at k-mart and sears and see if that helps.
Posted on Aug 03, 2010
Filter stops up on dishwasher
it is working correct, the salesman told you there was a disposal in the unit, there IS NOT. scrap and rinse your dishes prior to starting, also run your sink to get hot water prior to start. the heater is not for heating water.
Jan 06, 2012 | Maytag Dishwashers
When dishwasher drains the water not all the water is drained. Some stays standing at the bottom and starts getting an odor after awhile. This is a replacement dishwasher in a 35 year old house. How...
It's most likely that the filters in your dishwasher are blocked, the best way to clean them is to remove the filters from the bottom of the dishwasher, place them in the racks and run through the hottest wash cycle. It also helps to have a dishwasher cleaner inside the machine at the same time, these are available from most places that sell the dishwasher powder.
May 15, 2017 | Whirlpool DU1055XTS Built-in Dishwasher
Dishes and glasses not getting clean. visual inspection; it looks fine inside. removed filter and bottom perforated filter panel and cleaned off mineral-like residue. Ran test program: result flashing...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jun 14, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Doesn't clean properly, Leaves dry residue in washer
My dishwasher had the same problem. glasses were cloudy, inside the dishwasher was coated with a film, drawers were hard to pull out. tried rinse agents and vinegar and nothing worked. Found lemi-shine at WalMart (it's next to the dishwasher detergent) and the white stuff is gone! no more residue and glasses sparkle again. I was ready to buy a new dishwasher I was so frustrated. get some - it's amazing! a couple bucks and it's back to normal. I was SOOOO happy!
May 21, 2010 | Siemens 24 in. SL84A305UC Built-in...
Dishes on top rack do not come out clean. Bottom rack O.K.
Have you tried cleaning the filter? We had a similar problem. The repair man came and removed all the spinners and the other stuff at the bottom above the motor to get to the filter. It was blocked with all kinds of old food bits and pieces, the odd bit of plastic film etc. He cleaned it, replaced it and we havn't had a problem since but he said it needs to be done about every two years. It can be done by someone who has reasonable DYI skills.
Jan 04, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Draino in dishwasher?
Absolutely not! There are a couple of products that you can use that will clean your filters efficiently. The first is GLISTEN... The second is DISHWASHER MAGIC. Follow the application directions, This should clear your filters. In some extreme cases you may need to follow up with a second application.
May 04, 2009 | Frigidaire ATF6000ES Front Load Washer
How do I clean Hunter Humidifier # 34407 Nite Glo
the brown stuff is dust dirt unless you smoke then its that if you have washabule filter then wash it if not you must buy replacement filter thank you for useing fixya
Feb 17, 2009 | Hunter CareFree Plus 33222 Humidifier
Dishwasher
Most dishwashers have a little filter basket in the bottom. Depending on the brand, you can slide out the bottom rack, and in the bottom underneath the sprayer (the propeller thing) there should be some sort of basket that can be removed and cleaned. You also may have some water quality issues, or some detergents will leave residue. Also, make sure most of the large food is removed before loading.
Nov 05, 2007 | Baumatic 24 in. BFD60SS Free-standing...
GE GSD2200G02CC dishwasher
Your dishwasher probably has rotating blades on the top and bottom that spray water on the dishes.  Clean these off and make sure the holes are not clogged.
Sep 14, 2006 | GE GSD2200Z Dishwasher
Dishwasher is leaving food particles everywhere
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here http://www.appliancepartspros.com/partsearch/model.aspx?model_id=41284 then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 03, 2006 | Admiral 24 in. DWUA800AA Built-in...
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
