Canon imagerunner c3220 code E000020-0434 - Office Equipment & Supplies
SOURCE: Canon C3220 PDF print problems
http://www.adobeforums.com/webx?14@@.3bca0e93/7
Posted on Apr 28, 2008
InLikeFlin
SOURCE: Canon Color Imagerunner c3220
Go to the Printer Tab, select Printer Status/Settings, select Functions, go to page 2, select Run Setup, select Yes, and then you're in like Flynn.
Posted on Jan 15, 2009
SOURCE: Canon Imagerunner C3220 Network Folder Authorization
How can I clear the userid/password entered from the touch panel
Posted on Mar 12, 2010
SOURCE: Error code E000020 - 0081 in ir C3170 PCL5c
Posted on Jun 04, 2010
  • 6 Answers
SOURCE: Imagerunner c3220 error code E000602-0007
The Official Canon solution is as follows:
1. Replace the 512 Meg memory dimm.
2. Perform and MN-CON clear. (*28*>Copier>Function>Clear>MN-CON)
3. Perform a HD Format and System Software load.
4. Reboot the imageRUNNER.
You may be able to use regular memory to replace the copiers memory.
To perform the MN-CONT clear, you need to enter service mode. This is done by hitting the "additional functions" key, then hitting the 2 and 8 keys together, then hitting "additional functions" once more. Then you need to go to Copier>Function>Clear and highlight "MN-CONT". Hit OK.
You would need a service tech with the proper tools to perform the hard drive format and the system software install.
You might be able to just do the first 2 steps.
This will probably clear all the settings back to the factory settings as well. Beware.
Posted on Mar 01, 2011
How to repair canon ir C3220 Error Code E602-0003
This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. Just a guess. If you have an owners manual, I would check there to find how to solve the problem. You might want to enter the "menu" if there is one, and discover whether you can solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section.
Nov 11, 2013 | Canon Color C3220 Copier - Color...
Error code 000804-004
www.digitalcopiersolutions.com/clc-3220.html
Color Copier Canon ImageRunner C3220, Canon's true definition of multifunction has been met. should find all on here x
Mar 14, 2013 | Canon imageRUNNER C3220 Color Copier
Error code E000003-0001on Canon ir C3220
this is problem with the thermistor .
because the fixing temperature doesn't rise. maximum rise up to 70 degrees C.
solution is change the thermistor with a new.
Jul 21, 2011 | Canon imageRUNNER C3220 Color Copier
How do I sent my Canon ImageRunner C3220 to copy in black and white as the default?
First set it to B/W on screen then in additional functions /copy settings/page down to store settings then store and reset to quit.
Nov 24, 2009 | Canon imageRUNNER C3220 Color Copier
I have error code E00580-000 for my cannon imagerunner copier model C3220. Can anyone help me.
error is related to the finisher(stacker up-down movement). the hight sensor may have a problem
Nov 16, 2009 | Canon imageRUNNER C3220 Color Copier
Mar 14, 2009 | Canon Color C3220 Copier - Color...
Canon Imagerunner 2220i Error Code E000000-0000
canon printer ir 2200 error E000000-0000 my help
Feb 05, 2009 | Canon imageRUNNER C3220 Color Copier
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
Nov 12, 2007 | Canon imageRUNNER C3220 Printer
195 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
