Question about Nokia 3230 Cellular Phone
How to solve network problem
Which parts need to replacr, to solve the network problem, for most of the set.
  • Nokia Master
  • 4,737 Answers
In most cases, replacing is not so important, but since i used to repair this model Nokia 3230, i know there's default network problem with this model. I came across several times, seems not with the hardware, but with the case (cabinet) where the network antenna is coiled around. I used to clean them using the IPA solution with soft brush (or you can use alcohol/spirit/acetone, but the best is IPA solution since it's made for the similar purpose). But before this, you need to disassemble the handset, otherwise you'll not be able to do it.
On the other hand, refreshing (giving heat with Pcb blower using a specific paste) the network ic do the trick. We always need to be very careful handling the blower since a slight or a little higher air pressure can blow away the network ic. I hope you know all these since you are going to repair it.
You can also flash the mobile to make sure there's no problem with the software.
Your last option is replacing the network ic, but i don't recommend this, most technician will charge you very high for this, as you know it's risky and if it fails, they'll replace the handset. We charge nearly the price of a used same model, and no one can assure that it'll definitely work after replacing the ic.
The problem could be related to many issues, so there's no specific solution as well. I am just giving the most common and basics solutions for the same.
Good luck.
Thanks for using FixYa.
Posted on Aug 03, 2010
When you Galaxy Samsung Say Not registered on network when you trying to call someone How to fix that
According to WikiNix.com:
Step 1:
First, go to Settings.
Step 2:
Then go to Wireless and networks.
Step 3:
Then Tap Mobile Networks (If mobile networks not found then tap More settings and then find and tap Mobile networks). Watch video to understand and solve this issue easily.
Step 4:
Now tap Networks operators.
Step 5:
After complete searching.... Then select your Network Operator (Like Vodafone, Idea, AirTel, etc.)
That's it, problem solved.
Updated Fix 1. In Mobile Networks, set Network mode as WCDMA only and restart your phone. After restarting, follow above steps. That.s it (Updated on 12 September 2014). "
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
May 10, 2015 | Samsung Cell Phones
Change throw out bearing in a 2010 kia sportage
remove transmission and transfer case, its on the nose shaft of tranny in the forks make sure you replacr pilot bearing while your there well you might as well change the clutch too
Sep 29, 2014 | 2010 Kia Sportage 2.0
I need a diagram on how to attach a drive cable to a craftsman 6.5 hp ez start self propelled lawn mower.
just get new cable look at old study it how it goes on take off replacr in reverse order new one
Aug 25, 2014 | Garden
Truck struggles to back up
drain the fluid and clean or replacr the filter
Jan 21, 2013 | 1991 Chevrolet C2500
Replacr sprrd sesor 99 ford turus
The speed sensor is located on the side of the gearbox case. It should require one bolt to be removed, and it's wiring decoupled, and 'pop' it should pull right out.
Nov 08, 2012 | Cars & Trucks
Maytag microwave suddenly died after 20 seconds of use - lost all power. Outlet is good. Anyone else experienced this? My cup of tea looks sooo sad - like my wallet... Appreciate your time and...
Replacr the internal fuse you will find when you remove the cabinet. It will be near where the cord enters the cabinet. It is a special fuse ... get a replacement at most hardware of appliance parts stores.
Aug 31, 2010 | Maytag MMV5000 Microwave Oven
I am trying to replacr the cartridge on a 7310
You need a Moen cartridge puller or a plumber who has one on his truck.
Mar 14, 2010 | Moen 7310 Legend Single-Handle Kitchen...
How to solve replacr drum error
Laser printers need replacement of the drum after a few thousand pages printed. You need to read the user manual to get the part number and contact your computer store to request the part.
Providing a model number may help to give you the part number.
Dec 02, 2009 | Canon Office Equipment & Supplies
NO PROBLEM, I WOULD JUST LIKE TO REPLACR THE SCREEN....
I feel just explaining in words might confuse you so have attached a link which will be very helpful to you.rate me if i helped you.Thank you http://www.formymobile.co.uk/Dismantle/5300disassembly.htm
Oct 14, 2009 | Nokia 5300 Grey Cellular Phone
No this did not solve my problem. i am looking
"Network settings" is a very broad term. I have to assume you don't have a manual to refer to to find the setting you need to change. Use this link to see the entire user's guide...
http://support.dell.com/support/edocs/network/p57205/en/index.htm
Mar 03, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Nokia 3230 Cellular Phone Logo
106 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
