Question about Dryers
Whirlpool awz3518, red clean filter lights keeps coming on and stops programme , I've taken off the front of the machine and cleaned right down to the extraction fan , still no good , any ideas?
3 Suggested Answers
  • 289 Answers
SOURCE: i have a whirlpool tumble dryer awz3518, that has
run the dryer with out the vent hose hooked up.if the dryer work's than you have a problem with the vent system.check your vent hose from the dryer to the outside vent.
Posted on Dec 29, 2009
SOURCE: whirlpool awz3518 'Clean Filter' light is flashing
It would appear that this issue is related to a cold location, or the arctic air coming in through the vent hose.Sort of defeats the purpose of a dryer not working when its cold.
Posted on Jan 05, 2011
How do I clean the pump on a front loader Whirlpool washing machine, when the filter is spotless. (Red Pump clean light is on) Machine doesn't drain properly leaving clothes soaked.
If you have a top front small panel, unscrew 3 or 4 screw then you can pop out the cover. The pump is right there, you can counter clockwise the filter out and clean the pump. Be aware to do it with the power off.
If you don't see the front small panel, you have to open the back cover at the back of the unit.
Oct 13, 2013 | Whirlpool Washing Machines
CLEAN PUMP LIGHT COMES ON WHERE IS THE PUMP LOCATED
The pump is located behind front bottom panel on the right side assuming that your machine is a Whirlpool or Kenmore Front-Loader. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 13, 2010 | Whirlpool Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
Whirlpool awz3518 'Clean Filter' light is flashing
Dec 23, 2009 | Whirlpool Dryers
I have a whirlpool tumble dryer awz3518, that has a flahing filter light on it, but the filter is clean and the dryer is still wont work
Dec 22, 2009 | Whirlpool LER4634J Electric Dryer
How do I clean my whirlpool washing machine pump? The red light of my washing machine is on and it is saying clean washing machine pump and my washing machine door won't open.
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Macine has stopped working...''clean pump'' light has come on
Remove the bottom panel, 3 screws. Drop the panel down. The pump will be in front of you.
Twist to the left and remove the filter, clean it and replace it.
Mar 18, 2009 | Whirlpool Washing Machines
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Whirlpool clean pump problem
This is from the Whirlpool user manual for the AWO\R 4205 - it tried it and it worked well, found a hair grip and some stones in mine!
We recommend that you check and clean the filter
regularly, at least two or three times a year.
Especially:
If the appliance is not draining properly or if it fails to
perform spin cycles.
. If the pump is blocked by a foreign body (e.g. buttons,
coins or safety pins).
IMPORTANT: make sure the water has cooled
before draining the appliance.
1.
Stop the appliance and unplug it.
2. Remove the plinth by using the separator of the
detergent dispenser (fig. .A.).
3. Place a container beneath it.
4. Open the filter but do not remove it completely.
Slowly turn the filter counterclockwise (fig. .B.) until
the water begins to drain out.
5. Wait until all the water has drained.
6. Now unscrew the filter completely and remove it.
7. Clean the filter and the filter chamber.
8. Check that the pump rotor moves freely.
9. Re-insert the filter and screw it in clockwise as far as it
will go.
10. Pour about 1 litre of water into the detergent drawer
to reactivate the .Eco system.. Check that the filter is
inserted properly and securely.
11. Reinstall the plinth.
12. Plug in the appliance again.
13. Select a programme and start it.
Dec 16, 2007 | Washing Machines
Dryers Logo
108 people viewed this question
Top Dryers Experts
Marvin
Marvin
