Question about Panasonic KX-T7453 Corded Phone
Model kx-tc 1743W some of the keys in the dial pad have to be pushed more than once, or pushed harder to make contact.
  • 81 Answers
This may be caused by accumulation of dirt.
- Turn the box upside down and blow the keys and give it a gentle bang
Posted on Aug 03, 2010
Answer too fast
Here is a link where you can download the user manual for free which will explain how to set the phone to answer after a certain number of rings. Just go to the link its already set up just click on the download link.
http://www.retrevo.com/s/Panasonic-KX-TC1743W-Telephones-review-manual/id/2914bh651/t/1-2/
Mar 23, 2008 | Panasonic KX TC1743W Cordless Phone...
How do I change the time for daylight savings on a Panasonic KX_T7731?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following.
1. Push PROGRAM key
2. Dial "0"
3. Enter year (last 2 digits)
4. Enter month (01-12)
5. Enter day (01-31)
6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.)
7. Enter Hour (01-12)
8. Enter Minute (00-59)
9. Press 0 for AM 1 for PM
10. Press "AUTO DIAL/STORE" key
11. Push PROGRAM key to return to normal mode.
Mar 15, 2010 | Panasonic KX-T7731 Corded Phone
My panasonic kx-tsc10mxw keypad locked
take this:
1- Press Function
2- Press Down button until menu “Change password” displayed -> ENTER
3- " Current password " : Press this Number "726276642" -> Enter
4- “New password”
5- 0000 ENTER
6- EXIT
7- Press DIAL LOCK KEY
Jul 12, 2009 | Panasonic Lands Phones
My Panasonic Telephone Model KX-TSC35JXW dial pad is locked
I am having a Panasonic Telephone Model No.KX-TSC35JXW but I am not able to make calls because it is telling that the dial is locked but i dont know how to solve the problem.Please help me.
Jun 22, 2009 | Panasonic Lands Phones
Where to get new key pad
you need to pull it a part and cleen the push butons under the carban with matho cheers peter
Apr 05, 2009 | Panasonic KX-TG2382 Cordless Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Buttons
It sounds like the dial pad has built up carbon on the circuit board. If possible, disassemble the handset, and clean the circuit board below the dial pad with alcohol. Denatured alcohol works best.
also, clean the back of the dial pad itself.
Oct 29, 2008 | Uniden EXS 9910 Phone (EXS9910-R)
Key Pad buttons require more force to accept the input - loosing memory!
I have the same phone with the same problem and didn't want to part with it either. The cause of the problem are skin oils that seep down the rubber keys, and through slots at the base of the molded pad, thereby interfering with electrical contact. There is a vendor on ebay that sells a tape like pad with larger contacts that solves the problem perfectly. Go to ebay and use the following search term (I know this isn't the same model number, but its apparently compatible) :
Panasonic KX-TGA230 KX-TGA270 KX-TGA230B BUTTON FIX
The price is 5.95 including shipping. The repair pad will come with an instruction sheet, or you can go to the website on the instruction sheet and download about a 40Meg video file that shows you exactly how to make the repair. My phone operates with a nice light touch now that its fixed. Good luck.
Aug 24, 2008 | Panasonic KX-TG2383 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
205 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
