Question about Dishwashers
I get a code on a Fridge dishwasher model # GPDB998JC1 of "LO"---the unit seems to be working ok but the code comes up every time. I can push the cancel button and it will go off and then I can stat another cycle
  • 6,784 Answers
HI. This is not a serious component issue at all. No need to worry. The 'LO' is in reference to the Rinse aid level. It is a bit low in the dispenser. There is no need to replace a component in this case. Simply, refill your rinse aid dispenser. That will correct the issue.
Posted on Aug 03, 2010
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Bosch Dishwasher Model shu9915uc
ok sir! maybe you have defective motor thats why your unit is in abnormal power.
Oct 23, 2007 | Bosch SHU9915UC Dishwasher
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Seems to start and then cancels and drains
The flood switch might be turning on. This is the float unit at the base of the dishwasher. Could be the that the spring is faulty. Press and see if it comes back up. Otherwise there is leak in the dishwasher and water has collected at the base under the switch.
May need the actual model number to provide a more precise solution.
Feb 15, 2014 | KitchenAid Dishwashers
SDW60 - AL08 Error - No Hot Water
Hi fridge-1,
I had the same problem and fixed it by fitting a new control board .
Best of luck.
michael-howe
May 03, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Our dishwasher came without a manual . It runs FOREVER. Normal?
ok ...you have a wee bit of a problem...a new dishwasher even a floor model has a warranty..just call for service...best buy will send someone,,,now all units come with everthing accept electrical cord,,,i could only find drain hose part number 8269144,,but for owners manual go to servicematters.com..last just go back to best buy and find your model and see if you can get part number off installation kit..inside new unit.../
Jan 05, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
