Panasonic 5 disc changer (SA-AK450) is stuck on 1 track; doesn't change tracks. What to do?
    Guru:
  • 642 Answers
It seem you have activated repeat on the unit.
To deactivate press repeat button on the remote. righthand button 2nd row of buttons from the bottom
Posted on Aug 03, 2010
Will not play CD's
Disc is dirty or the pickup lens has dirt on it. Needs to be seen by a Technician to resolve.
Dec 26, 2012 | JVC XL-F154BK 5-Disc CD Changer
CD player clicks while playing some CD's
Sounds like it's worn out, best take into the shop for repair, should only cost $20 with parts.
Dec 25, 2017 | Pioneer PD-M426 6-Disc CD Changer
Jaguar 6 disc player not working
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 22, 2012 | 2005 Jaguar X-Type
A homemade CD got caught in the turntable and now the turntable is stuck even after removing the CD.
Try this:1. Remove the cover (2 screws on each side & 3 in the back).
2. Find a small white arm (more or less cylindrical, about 1" diameter, & about 3/4" long) and a longer (4-5"?) thin black arm in the center of the unit. These parts load/unload CDs to/from the playing area. You should see that a little knob on the white piece has jumped out of its track in the black piece.
3. Carefully put the knob on the white piece back in its track in the black piece. That should do it.
Feb 20, 2011 | Pioneer PD-F1007 301-Disc CD Changer
My Honda accord Sedan car CD Player cannot eject CD .
Before connecting any cables you must set the dip switch box to the position listed for your vehicle. If you set the dip-switches after you have connected cables to the box, you must disconnect and reconnect them for the changer to operate. All 1992-2004 Honda's are compatible with the Neo Changer except the 2003 and 2004 Honda Accord and all Honda Element vehicles. Some radio models require pressing "Seek >" once to start playing after changing CD or after startup. The radios display will not show the proper disc number after disc six. You can use all 10 discs in the magazine, but the readout will be wrong. This is not a technical problem; the car stereo was designed for no more than six discs. *Due to the direct access disc system, you will not be able to directly access discs 7-10. To access these discs you will have to go to the last track on disc 6 and let it play until it loads disc #7. ( you can fast forward the track, but you must let it play the last 5 seconds of the track, for it to change to disc # 7 Switch to the Neo Changer by pressing the "CD" button. To change discs press "Disc -" and "Disc +" To change tracks simply press "Seek <" or "Seek >" S E T T I N G S F O R H O N D A 1 2 3 4 5 6 7 8 ON OFF OFF ON OFF OFF ON OFF
Dec 21, 2010 | 2000 Honda Accord
Hello. I have a panasonic sa-ak45 and drive left open, what happens is that when you press the button open / close it just displays the message "changing" and never goes out of disk 1. It will be a...
The disk jumped from the internat platform , you must open the back case and push the CD a little. He is stucked somewhere betwen. It's very easy . just 12 screws
Sep 02, 2010 | Panasonic SCAK410 5-Disc CD Changer
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Pause between tracks
sounds like a setup problem the unit can be programmed to pause between tracks, if not the you have a cd mech problem, possible dirty laser or debris in the sled motor gears. causing the laser to be sluggish when changing tracks
May 30, 2008 | RCA RP8078 5-Disc CD Changer
99 people viewed this question
 Grubhead
Grubhead
