Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
The pump is running but not pumping much water even though the filter is clean
  • 640 Answers
It sounds like your connections in your pool filters might not be tight or you might have a leak. Check your entire pump and filter to make sure that there are no leaks or loose connections.
Posted on Sep 08, 2010
Bdc600xl water will not filter through. Grinder works just fine. Checked that it was clean. Is.
The pump may be jammed. I'm not sure about these units or if the pump is serviceable. You would probably have to strip off the covers and check the hoses for blockages first then determine how the pump comes out. You should be able to hear the pump working, if not, I would say its jammed.
Aug 24, 2016 | Breville Bdc600xl YouBrew Drip Coffee...
Pool water will not circulate even though pump is running
if the water doesnt circulate, there could be many causes. start at the very beginning. does the pump sound 'normal'? if there is rattling or buzzing, the pump might not be turning and there fore no circulation. is there water in the system? even though most pumps are 'self priming', you should fill the hopper with water to prime it. are the lines open? make sure the supply to pump from skimmer is free of blockage and that the return lines to pool are open and free from blockage. if all this looks fine, then you have to get deeper into diagnosis.
Dec 20, 2015 | Hayward Pool & Spa
Who often should I backwash sandfilter
I would let it run for about a minute depending on how clogged it was. Our backwash drain is very visible so we can see when the dirty water has left the filter, usually about a minute or two.
Apr 06, 2013 | Hayward SAND FILTER, PRO SERIES
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
Adjusting my Pentax hydromatic H1 water pump
we need wiring diagram for achromatic 1. the power supply is 240 v 50 hz
Nov 26, 2012 | Cars & Trucks
Water will not drain out but the water pump keeps running even when the door is openned or closed.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Asko 24 in. D3120 Dishwasher
Pressure on the EC65 is always high
Certainly sounds like a filter problem. Here's a couple of things to try.#1. i don't know how you cleaned the filters but clean them again with a good filter cleaner/degreaser.#2. After a good cleaning, get a bucket large enough to hold the filter fingers in and give them an acid bath. They recommend a 20 to 1 ratio of water to acid (muriatic) but I personally don' think thats strong enough. Use a good amount of acid and let the fingers soak for a good ten or fifteen minutes. (always add acid to water, not water to acid) Rinse and reassemble filter. If that does'nt solve problem, I think it's time to replace filter.
Jun 17, 2010 | Hayward EC65 Extended Cycle DE In Ground...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
242 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
