Question about Kenwood KAC-X650D Car Audio Amplifier
My amp overheats..
My Kenwood 1000 watt amp overheats every 15 minutes of constant playing...How do I prvent that from happining?
    Novelist:
  • 100 Answers
Do you mean that it actually over heats and shuts down? If it does then make sure you aren't trying to over drive it or underdrive the impedence. A good suggestion for cooling is get some 1/4" spacers and space the amp up off of the surface you mounted it too. I did it when I had my 2 Memphis M-Class 500Ws and just doing that they were cooler. Also make sure it is not mounted in a restricted air flow spot. If it is put some cooling fans by it to circulate some of the air. Let me know if you need some more help. Good luck.
-Andrew Hawkins
Posted on May 01, 2008
How many amps do I need for a 1000 watt appliance?
Watts = Amps X Volts
1000 = Amps X 120
Amps = 1000 / 120 = 8.3
Mar 09, 2015 | Home
I would be playing with my amp and after about 30 min there will be a a lot of crackling and then the amp shuts off
You are driving the amp too hard and the thermal protection in the amp chip is cutting out.
Either reduce the volume on this small amp or get a larger unit.
The heat sinks for the amp chip will overheat if you drive it hard and that takes a bit of time to happen, hence the 30 minute delay.
Jun 10, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Car audio
If you are asking if you can have a kenwood amp hooked up to your Sony Head unit then yes it would be compatable.
Jun 02, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
Can i run just 2 subs on this 1200 watt kenwood 5-4-3 and if so what way will i get the most power, i mean do i bridge it or pute the speaker wires in other ports
you can run 2 subs given that you dont go over 2 ohms of resistance and that the subs are rated at 1000 watt max each around 4 or 500 watt rms. if your not sure about ohms dont bridge it and get single voice coil subs. this amp is capable of about 700watts constant power 1200 max spike if the voltage stays at 12 or higher.
Feb 05, 2010 | Kenwood KAC-X650D Car Audio Amplifier
How well will a 1000 watt kenwood amp pump with 2 1200 watt suns
2 will push more air but be careful how they are wired so you dont go to low on the ohms your amp sees.That amp should be 2 ohm stable so read up on how to wire in series or parallel.
Sep 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Repeated blown subs
Unfortunately some of these speakers today... DO NOT PERFORM up to peak as they should.The on logical reason for this to be happening it that the speakers are NOT very DURABLE and cannot take constant playing. I would recommend to L7 the can take alot more abuse than your average speakers. Good luck and thanks for using FIX YA
Mar 23, 2009 | Kenwood KAC-X401M Car Audio Amplifier
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Jan 12, 2009 | Car Audio & Video
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-X650D Car Audio Amplifier Logo
430 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
