Question about Compaq Presario C700T Notebook
How do I import just a dozen pictures from a CD containing over 300 pictures?
  • Compaq Master
  • 11,800 Answers
Open the cd in My Computer and copy just the photo files you want.
Posted on Aug 03, 2010
Tip
Recovering your data before reinstall with ubuntu.
If you have lost your password, or if you are unable to start up windows and it seems like you would have to do a fresh install of windows.
In the process you may lose all your files, if the drive is formatted, to avoid that happening download ubuntu and burn it to a cd.
things needed:
  • A working computer w/ cd burning capability
  • 1 empty CD-R disk
  • External hard drive (USB) for backing up your files.
download ubuntu http://www.ubuntu.com/ and burn it to a cd, then start up from the disc and back up your files into the external usb drive. The downloading and burning of the disc, the ubuntu site explains and has everything you need for this task.
Start your machine with the cd, and connect the usb hard drive. if the machine does not start from the cd, confirm that the disc works on another computer and make sure its clean, then check the boot order by following my tip on troubleshooting boot cd issues.
with the cd in the drive and it starts up, take the option to Try ubuntu without any change to your computer.
In ubuntu, it is quite like a windows system, its as simple to use as windows is.
In ubuntu, with the external usb drive connected, on the desktop
On the top right you have places, from there you can get into your computers hard drive and then on the usb drive, just copy your files from there to the external just like you would do with a windows computer.
Things that you want to back up
documents and settings your user name --- this place contains your personal data in most cases
any other place that you know contains something important.
that is the most important place and that is where most of the files are stored, of course you will know better what and where they are.
Things that you don't want to back up
program files, contains the installed programs of your computer, most of the time it is not a good idea to back up these files as programs need to be reinstalled when a new install of windows is made, since we are not backing up registry entries for the programs they may not work properly.
windows, contains the windows installation very rarely would you have anything important there, ignore it
temp, contains temporary files, unless you stored something important there ignore it.
If you kept something important in the recycle bin you can possibly find a hidden folder of recycler or similar in the drive where you may find some of your files, do not store your content in the recycle bin, it is not a good idea to store anything there.
When you have backed up your files you can do a fresh install of windows, for help in that please see my tips and tricks section for more guidance.
on Dec 25, 2009 | Computers & Internet
Tip
File Contains No Message
This is for you, if when you go to look at pictures on your camera that you have already taken, and a message appeares on the screen that says: file contains no message. This happened to me. Don't panic. This happens when you accidently cut your pictures from your sd card, and put them in another folder, so you can look at them. Follow these steps:
1. Delete the messages that say: file contains no message off your camera.
2. The pictures should be already on your computer.
3. Save your pictures to a blank CD.
4. Go to a store with the CD, and get your pictures developed.
I hope this helps.
on Jan 07, 2009 | Polaroid a300 Digital Camera
Windows 7 refused to update. Windows 7 refuses to
  1. Do one of the following:
    • Connect a camera to your computer by using the camera's USB cable, and then turn on the camera.
    • Connect a portable device that contains pictures or videos to your computer by using the device's USB cable, and then turn on the device.
    • Insert a removable flash memory card, such as a Secure Digital (SD) or CompactFlash memory card into a memory card reader.
    • Connect a scanner to your computer by using a USB cable, and then turn on the scanner.
    • Insert a data CD or DVD that contains pictures or videos into your CD/DVD drive.
  2. In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
  3. To change the settings that are used when importing pictures and videos, click Import settings in the Import Pictures and Videos dialog box.
  4. Change one or more settings in the Import Settings dialog box, and then click OK.
  5. Click OK to restart Import Pictures and Videos. Type a tag in the Tag these pictures (optional) box, and then clickImport to import your pictures and videos using the new settings.
    For updates make sure that the time and date are correct, if it doesn't match what time it actually is , it wont update, and make sure your OS has been activated
Aug 29, 2013 | Dell Dimension 4700 PC Desktop
I HAVE A SONY DIGI CAM MODEL DSC W-5. MY PC IS NOW UPGRADED WITH WINDOWS VISTA AND SINCE THEN IT IS NOT POSSIBLE TO DOWNLOAD THE PICTURE TO PC. THE INSTALLATION CD ISSUED WITH CAMERA DOES NOT COMPITABLE...
  1. Turn on the camera.
  2. Insert the recording media containing the pictures into the camera.
  3. Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
  4. Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
    • Connection through a USB hub or other USB device -- such as a printer or keyboard -- is not supported and cannot be guaranteed. Connect the camera directly to a USB port on the computer.
    • If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
    NOTES:
    • The computer will automatically install the USB driver for the camera.
    • When the camera connection is established, an AutoPlay window will appear.
  5. In the AutoPlay window, click Import pictures .
  6. In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Here
(from Sony Website)
Mar 19, 2009 | Sony Cameras
Tip
I hope this helps.
on Jan 07, 2009 | Polaroid I533P Digital Camera
Tip
I hope this helps.
on Jan 07, 2009 | Polaroid T730 Digital Camera
CRT MONITOR MESSAGE ON SCREEN PRINT NOT REMOVE
If you are talking about a burned in image on a CRT screen, there is nothing you can do about it, except replace the picture tube, which usually costs much more than to replace the entire monitor.
Jan 27, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Tip
I hope this helps.
on Jan 07, 2009 | Polaroid i733LP Digital Camera
Tip
This is for you, if when you go to look at pictures on your camera that you have already taken, and a message appeares on the screen that says: file contains no message. This happened to me. Don't panic. This happens when you accidently cut your pictures from your sd card, and put them in another folder, so you can look at them. Follow these steps: 1. Delete the messages that say: file contains no message off your camera. 2. The pictures should be already on your computer. 3. Save your pictures to a blank CD. 4. Go to a store with the CD, and get your pictures developed. I hope this helps.
on Jan 02, 2009 | Nikon COOLPIX L18 Digital Camera
Compaq Presario C700T Notebook Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
