Question about Cell Phones
Says select network I do so (t-mobile 310/260) it says unfinished. what's wrong? What do I do to set up the network properly?
When you Galaxy Samsung Say Not registered on network when you trying to call someone How to fix that
According to WikiNix.com:
Step 1:
First, go to Settings.
Step 2:
Then go to Wireless and networks.
Step 3:
Then Tap Mobile Networks (If mobile networks not found then tap More settings and then find and tap Mobile networks). Watch video to understand and solve this issue easily.
Step 4:
Now tap Networks operators.
Step 5:
After complete searching.... Then select your Network Operator (Like Vodafone, Idea, AirTel, etc.)
That's it, problem solved.
Updated Fix 1. In Mobile Networks, set Network mode as WCDMA only and restart your phone. After restarting, follow above steps. That.s it (Updated on 12 September 2014). "
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
May 10, 2015 | Samsung Cell Phones
My phone worked fine now it says not registered on mobile network
remove the sim card and start the phone, keep it on for 10 seconds, switch it off, remove the battery and again keep it off for 10 seconds. Install the sim and switch it on. Hope it will help. Make sure the network searching mode is selected to automatic
Dec 29, 2014 | ZTE Cell Phones
How to make internet setting in samsung galaxy s duos s7562
Go to settings, select more under data usage
then select mobile network then select access point names and press menu. after that select new APN, type your network name at the name column and type internet at the APN column..u r done..
enjoy ur internet
Feb 05, 2013 | Samsung Galaxy S Duos S7562 White Dual SIM...
Desbloquear
Currently your LG KE970 Shine Locked to which Country's Network? You need to Unlock it using the Network Unlock code,get the Unlock code from here
Prounlocking and Unlock it...Follow the instructions below and Unlock it step by step...
LG KE970 SHINE Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your LG KE970 SHINE mobile phones. If you enter over a certain amount of wrong unlock codes on your LG KE970 SHINE mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your LG KE970 SHINE with its ORIGINAL SIM Card.
2 - Then compose : 2945#*9701#.
3 - In the menu that appears go to "Settings".
4 - Then select "Security".
5 - To finish select "SIM Lock" and Enter the Unlock Code.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG KE970 SHINE.
Each LG KE970 SHINE mobile phone has an unique unlock code. You can buy the unique unlock code for your LG KE970 SHINE mobile phone using the form above.
Jun 19, 2011 | LG Shine KE970 Cellular Phone
How to use Nokia 6030 in US (T- mobile) which i bought in India.. This mobile is an unlocked mobile.. i was using with different networks in INDIA.. i bought this mobile in 2007.. so far i never had...
Try this:
Go to Settings > Network Settings > Network Mode and make sure Dual Mode is selected, if not select it by pressing the Ok button and choose Dual Mode.
Also go to Settings > Network Settings > Operator Selection and verify if Automatic is selected or not.
If both the above methods don't help, restore the phone to it's default settings. Go to Settings > Factory Default or Restore Factory and select it to proceed, if you are asked to enter security code, use 12345 (by default).
If this doesn't work, I think your phone has some problem or your phone is locked to some or one network. Try another sim card and see if it works or not.
Note: The sequence I've mentioned above to enter the select settings are general for Nokia, it might be a little different or the name of the options might be different. Hope you'll get it somehow. If you have problem, let me know.
Good Luck.
Thanks for using FixYa.
Jun 12, 2011 | Nokia 6030 Cellular Phone
I have a samsung t746 impact from t-mobile, i m using it in haiti now with digicel, the phone works properly but unable to connect to internet because there is no option from the settings for connectivity,...
The phone needs the additional settings for setting up browser configurations with Digicel instead of t-mobile. Unlocking it simply takes off the carriers sim restricition and does not change settings to every carrier available. Digicel should have these settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/steven_958e67a4edcc47d5
May 02, 2011 | Samsung Highlight Cell Phone
What is network selection? which is better automatic a or b ?
Most GSM handsets offer a choice to select a new network, automatically or manually. The default setting, in most cases, is automatic, which instructs your mobile to automatically connect to the strongest network signal available. As you move, the handset will continually monitor the available networks, and keep you connected to the strongest one. In a manual network selection setting, your mobile handset will detect if there is more than one network present and offer you a choice. If you then select one network, your mobile phone will remain connected to it regardless of the alternative networks available. You may prefer to remain connected to one network if it offers cheaper outgoing call charges. To manually select networks please refer to your mobile phone user manual for instructions. Your Jersey Telecom SIM card can store a list of your preferred roaming partners. If you have an automatic network selection setting, and there are two networks of equal strength available, the mobile phones will connect you to the one that is highest on your SIM card’s preferred list. The list can be edited by using the appropriate menu on your mobile phone. Check your mobile phone user manual for details.
don"t forget to say thank's
Mar 31, 2010 | Motorola Mobility RAZR V3m Cellular Phone
M001 Phone when trying to make a call it says : NOT ALLOWED DIAL"
This is for another similar clone marked with the "vaio" name but it might be useful to someone out there. I found that by following solution one above (thanks Mrfixit) to step 6 as below and then following the second part of what I found at http://chinamobiles.org/archive/index.php/t-16088.html worked for me. I reproduce the steps below:
1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive
BUT THEN
Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!!
11. Press the Menu button (second from the left, the one with the seven small dots on it) until you are at the main menu with the 12 icons on the display.
12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup"
13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only"
14. The mobile will switch to your selection, but the message that it will stays on display. Do not press anything else, just wait for about 10 - 15 seconds.
15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection.
16. Get back to main menu, switch off and restart the mobile --> DONE
Sep 22, 2009 | Cell Phones
Cannot send texts
The result i found was to do with area info. Go to messages and select settings. make sure you go into area info and select reception ON. This corrected my problem i had with not sending messages.
May 21, 2009 | Sony Ericsson K850i Mobile Phone
CECT P168
It´s a problem of network settings... do you have a manual with provider settings?
Sep 14, 2008 | Dual Electronics CECT P168 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
