Question about Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor
My gas powered compressure runs good as far as it has 125psi in the tanks but no air comes out of mthe air hose
  • 843 Answers
The regulator pressure spring may be broken. Does the regulator knob turn freely both ways, but the gage stays at zero? If so, you need to replace the regulator.
Posted on Aug 03, 2010
Can the fuel filter in the gas tank be cleaned by blowing air pressure back into gas tank using a compressure
yes, and rinse the tank out with good gas or carburetor cleaner. just dont blow the filter out by using to much air.
Apr 13, 2017 | Garden
Will 3.8cfm @90lb pressure air compressure 10 gallon 125psi work with impact wrench at average air consumption 8cfm
Air tools demand volumes of air; a 10 gallon is good for something like a finish nailer, or staple gun, or even a nail gun.
It will run the impact wrench, just not for very long, like 10 to 12 seconds if you're lucky.
Most compressors tell you what types of tools they are made for.
And impact gun is best matched with a 21 - 26 gallon compressor.
Nov 03, 2015 | Air Tools & Compressors
While the compressor is running it gets between 100psi to 125psi and before it shuts off, it throws the relay switch. Please and thank you.
do not use an extension cord it will over time damage the motor plug straight into outlet and use longer hose.most household wall outlets cant handle the amp draw from air compressors most are 15 amps
Jul 07, 2011 | Ridgid Air Tools & Compressors
I have the clark 4 gallon compressor Model #AC2001B. When I pull the on switch the compressure attempts to start. It runs slowly for a few seconds then stops. I do not know why this occurs. Thanks
Hi I know these need to be very high powered so try plugging it in direct to the mains not an extension lead or use the mains from the house not a garage or outhouse hope this works!
Jun 22, 2011 | Clarke Power Products Inc AC2001 2HP 4...
Chevy uplander 2006 hesitation and loss of power
Check air filter, valve on hose leading to engine, and electrical connection on air intake hose.... vacuum in gas tank loosen gas cap and reseal...bad gas can do this to fill with known good gas and run a tank...spark plugs need replacing @ 100,000 Ks or 60,000 Ms the manual recommends 100,000 but many mechanics have reported that the lower mileage is the actual.....
Sep 09, 2010 | 2006 Chevrolet Uplander
Craftman 3gal/1hp air compressor runs normal, but
Chek for pressure BEFORE REGULATOR,if the problem remains worn rings or valve seats most likely source of trouble.
Aug 09, 2009 | Air Tools & Compressors
Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
Feb 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Ridgid 17038 4.5 Gallon Oil Free Twinstack Air Compressor Logo
160 people viewed this question
Top Ridgid Hammering Experts
Robert Wooley
Robert Wooley
Tim Whalen
Are you a Ridgid Hammering Expert? Answer questions, earn points and help others
