I only need natural gas in the winter to run my furnace. I have electric stove and water heater to try and save money. Even though I use no gas, The Gas Company charges fees that amount to approximately $30.00/Month. Before DeRegulation AGL didn't charge excessive monthly charges per month to maintain service. If I cancel service, I have cancellation fees and then in November when I sign up with another server, I have AGL hookup charges and charges by the Server to start Service. All Gas Customers were much better off with AGL who owns all the Gas lines. The Deregulation scam costs us dearly with no savings to the consumer from competition by the Servers. We at least need the ability to suspend service during the summer without paying monthly service fees while not using any Gas. Please let me know If I have any choices of suspending service or Canceling Service with disconnect & Connect Fees. Thanks, Joe Duncan
Vote for a democrat
Posted on Apr 25, 2008
Tip
Install Wood Stove Save Money on Heating
Fuel oil prices have been very volatile over the past few years. The price of electricity has increased dramatically for some areas recently and it will increase for many other areas in the near future. LP gas or Propane has jumped around with the changes in the oil pricing. The prices of natural gas have been fairly stable recently, but as fuel oil and electricity rise in cost the natural gas prices will follow as more and more large use customers convert to it to save money.
Even though the costs of many other home heating fuels has continued to rise the price of wood has stayed the same or even become lower. If you have easy access to this cheap fuel then you may want to consider burning wood as the way to heat your home.
The one fuel that has remained stable or dropped in price has been firewood. Because of the slowdown in the housing market many loggers that have been very busy for years cutting for lumber mills, now have time on their hands and are cutting firewood for some side money to survive and to just stay busy. Many timber stands that were under contract to be harvested are still standing because they are not worth cutting. All this means that if you are thinking about burning wood to heat your home, then now is the time to do it.
Check out the many possibilities that are available to use to heat your home comfortably and effectively. There are many ways that you can use to burn wood and heat easily and efficiently. Each home and situation is different. Make sure that you get the right wood burning appliance for your home.
http://www.fixya.com/support/r3595905-alternative_heating_pellet_stoves_and_pe
on Dec 24, 2009 | Heating & Cooling
Tip
2 Stage Furnaces More Comfort and Save Money
Two stage hot air furnaces can save you money and make your high efficiency furnace even better. With your furnace running at low fire instead of cranking up to the highest heating output in mild weather you can be more comfortable while saving money.
Many people think that they are getting the best they can get by buying a high efficiency single stage furnace. What they often don’t realize is that they could do better yet and for a few dollars more have a high efficiency 2 stage furnace that could keep them much more comfortable.
There are 2 stage hot air furnaces that are now available that will only run at half fire if the full fire is not needed. With a two stage furnace in mild weather when only a little bit of heat is needed, the furnace will have longer run times on low fire. This will keep you room temperatures from getting too hot before the thermostat reacts and shuts the furnace off again. This will help to keep your temperatures from overshooting the set point and help to keep your home much more comfortable.
Many of these two stage furnaces also have variable speed blowers that run at a lower speed when heating on low fire. This will also help to save money on your electric bill, because these blowers use very little electric when running at these low speeds. Air noise from the blower running at a high speed is also reduced.
If you are thinking of replacing or installing a hot air furnace, make sure that you ask your contractor to give you a price on installing a two stage furnace. The price difference probably will not be much higher than a high efficiency single stage furnace. However the comfort of the two stage furnace coupled with the electric savings will make the extra money well worth it.
on Dec 14, 2009 | Heating & Cooling
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
We have a Bosch AQ125BNG gas water heater. The pilot goes out in the middle of taking a shower and has to be relit. We have had this problem for a couple of years, but it only happens during winter months...
The problem is excessive down draft or condensation. Air flow is important in combustion appliances. Too much airflow down the chimney can blow the pilot out. This is readily apparent when it gets cold and there is air rushing down the chimney in the winter. There may be an air leak in the room with the water heater. While there should be a combustion air supply that is sufficient, there should not be a place for the air coming down the cold chimney to go. That would eliminate the draft. Another thing is if a furnace is in the same room and does not have enough air to supply the burners. IF it is an older furnace without a combustion exhaust fan or has its own flue, the air being drawn into the furnace burners may be blowing the pilot out. Last but not least is the condensation issue. When cold water enters the tank it can cause water to condensate on the outside and drip down into the burner and put the pilot out.
Jan 29, 2018 | Bosch AquaStar Indoor Natural Gas Tankless...
My gas furnace fires but then cuts out. There is a similar post on here about this but my problem is a little diiferent. The unit kicks on, fires then shuts right down. The blower comes on and stays on....
HAD A similiar problem last week with a customer who had just installed a pool and running off of propane tank for gouse as well... he let tank go empty and started having problems ..what we ended up finding is that not only was his regulator on tank bad he needed a additional regulator to regulate the different psi pressure to the appliances... get them to check your regulator out
Jan 24, 2011 | Goodman Heating & Cooling
Burned out Napolean stove.
Hi i would write to the company first asking about this problem see what they come back with bypass the rep go higher
Feb 12, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
Charmglow Ventless Wall heater stinks - Literally!
some suggestions that may help: a sulfer type smell is the additive in the natural gas, kind of like eggs. if this is your smell, you have a gas leak. if any other propellents like hair spray, furniture polish, air fresheners are nearby, the vapors are burned by the stove and you can smell those, as well as a fine white powder building up on the stove. if a paint smell, then check to see if the back wall of the stove paint is burning away. if so, you can speed the process with a small hand held torch used for plumbing. when the paint is gone, the smell is gone. good luck.
Dec 30, 2008 | Heating & Cooling
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
