My Innovair elite mini split AC has multiple prolems. 1. The coils are making ice. 2. On or Off it displays C2 3.Although I cleared the tracks still dripping water. 4. Just blowing cool.
  • 441 Answers
There should be a label on your AC system with a model number specific to your unit. Please reply with the exact model number and we can further assist you.
Posted on Aug 03, 2010
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Has stopped working and shows - E6 Model: Innovair
http://innovair.com/producten?cat=residential
This is the manufactures website. there is a contact page you can contact them at also can find a dealer from this page that may be in your area.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 09, 2013 | Heating & Cooling
Mini split drain trouble
There is a temp. probe on the inside unit.(evaporator). If you open the front panel you should see 2 white air filters. With the right side one removed you should see a black probe on the coil. Possibly that probe needs replacement. Very possible there is also a defrost sensor connected to the outside condensing unit. That sensor is connected via a white plug in connector.. Replace that one too if possible.
Jan 20, 2013 | Daikin FTXS12LVJU/RXS12LVJU 12000 BTU...
My innovair ac split control damaged where can I turn it On without a control?
mi remote control is damege how can turn it on with out the control ????
Jun 08, 2012 | Heating & Cooling
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Innovair Prestige mini split and I chance the braker switch but the airconditioner did not turn on. How can I resolve this?
you need to make sure you have power going to it and coming out of it why did you have to change the breaker it could be more serious problem inside the system
Sep 11, 2010 | Heating & Cooling
Ice formation on the fins- after about 20 minutes of putting it on, a comlete ice (snow) sheet forms on the fins-blocking airflow into the ac.
three possible prolems here 1 check the evaporator coil and filter to see if they are dirty and need to be cleaned dirt gets into the coil by by-passing the filter or the filter is no longer able to contain the dirt. 2 if there is a opening in your furnace that allows air to the furnance without going through the return air vent this could be a cause 3 low on freon in which a tech will be needed to check. Also check the outside unit and see if the coils have a lot of debris on them if so you can use a garden hose to clean them but make sure to have the power off and just spray the coils nothing else. Good luck
Dave
Oct 13, 2009 | Heating & Cooling
E4 in an innovair a/c
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
Heating & Cooling Logo
476 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
