Question about Dell 1710 Laser Printer
Dell Printer 1710 - shows an error on printer - 38 memory full . Please help
  • anilpinto Aug 04, 2010
    Could anybody help me on this issue please?
SOURCE: Dell 1710 Laser Printer
i had the same issue, but i fixed it. For whatever reason the contacts that are inside the printer were not making contact with the PCB ( printed Circuti board ) on the underside of the drum... i fixed the issue by cleaning the pcb and re-aligning the contacts inside the printer.
Posted on Jan 25, 2008
damanpreet_c
  • 69 Answers
SOURCE: hardware error:0502
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
SOURCE: after replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Posted on May 14, 2009
frcs68
  • 1605 Answers
SOURCE: how do I clear data from my RAM disk on Dell 3100cn printer
The RAM for the printer is temporary.
turn off the printer and unplug the printer from the outlet. wait for 20 sec. plug the printer in and turn it on.
you can select in the printer properties page of the printer to print immediately instead of spool and print from the last page first. that will eliminated the ob store in the RAM.
Posted on May 15, 2009
  • 320 Answers
SOURCE: How to reset to factory default Dell 1720 network printer
1. Turn off the printer
2. Open the front cover.
3. While the Continue and Cancel buttons are depressed, turn the printer on.
4. When the error LED on the control panel is lit solid, close the cover.
Posted on Aug 28, 2009
My dell 1710 cant print it keeps showing or blinking " !" sign
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
There is a link to your printers manual that includes troubleshooting error codes. The blinking exclamation point means that the printers cover is not closed all the way. If there are any other pictures on the printers display that are also blinking like an ink drop or a sun then it can mean something else.
Oct 14, 2011 | Dell 1710 Laser Printer
My printer dell 1710 has bee blinking "!" and
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
Dell 1710 wont pull paper. Little turner with rings will not go down, but the rings turn.
Please turn the printer off then open side or rear panel, gently remove stuck paper, then power printer back on.
Jan 09, 2011 | Dell 1710 Laser Printer
I have Dell 1710 Laser printer. Toner and Error lights are on and the printer doesn't go online. Can anyone help?
You need to replace the toner. Printer shuts down when print counter reaches it's limit on the toner cartridge
Apr 24, 2009 | Dell 1710 Laser Printer
After replacing toner cartridge, error/toner lights stay on
Apr 02, 2009 | Dell 1710 Laser Printer
Help
There is no setting on the 1710 printer to clear the error of a non Dell branded toner being inserted. Some higher end Dell printers do have a setting for Non-Dell branded toner. Not all Dell printers have this setting. Resetting the drum count will have no effect on a non dell branded toner error.
Nov 07, 2008 | Dell 1710n Laser Printer
Dell 1710
it's in the menu, under settings. reset to default and then power cycle it again...sounds like your memory is a bit corrupted(comes from power glitches)
Jan 18, 2008 | Dell 1710n Laser Printer
Dell 1710
If that is the only light:
Remove the toner cartridge and firmly shake it from side-to-side and front-to-back several to use the
remaining toner, and then reinsert it and continue printing. Repeat this procedure multiple times until
the print remains faded. When the print remains faded, replace the toner cartridge
If not let me know.
Nov 16, 2007 | Dell 1700n Laser Printer
Printer- On Line/Error
Download the status monitor for the ML-1710 and when you switch on the machine the monitor should help to give you an indication of what the error is. Post that info back here for further help. Unfortunately there is insufficient information here to help you further. The status monitor may give you an error code - this will help us help you further.
Sep 16, 2007 | Samsung ML 1710 Laser Printer
Dell 1710 Laser Printer Logo
126 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
