Question about Nikon D5000 Digital Camera
My nikon camera wont turn on ? possible battery or what ? I was using my camera last night and wnet to change the camera card and camera shut off and since then wont go on . have cahrged it and stilll donet work
  • 906 Answers
Link
It's best to consult the Nikon Center near you for this problem. However, I have attached a link above wherein you can browse about your camera. If, the camera is more roughly old, possible the problem is with the battery. --it needs to be replace. But if the camera card is not compatible with your camera, that might be the problem came from.
But, I would still suggest that you asked your Nikon Support Center near you.
Thank you.
Posted on Aug 03, 2010
    Brigadier General:
  • 3,006 Answers
Batteries can and do fail suddenly, and totally dead electrical devices are impossible to diagnose faults on without specialist tools and knowledge.
You only have two choices:-
1. Replace the battery with a known good, fully charged one to see whether it resolves the fault. If you have to buy a battery for this test then you may end up buying a battery unnecessarily if it proves that the fault is not with the battery. If you know anyone with another D5000, D40 or D60 then you may wish to test your battery in their camera, but then you risk damaging their camera if your battery is faulty (unlikely with most faults, but definitely possible). You can also ensure that your charger is not faulty by charging your battery on a borrowed charger (same warnings apply though).
2. Skip the battery test and return the camera to an authorised Nikon Service Centre. Your camera is less than two years old so may still be under the manufacturer's warranty, but you'll need proof of purchase and the original warranty card to benefit from a warranty repair and the exact terms vary worldwide. If you're in the UK you need to have purchased from a source supplied by Nikon UK and republic of Ireland and to have registered the warranty within 30 days of purchase. In the UK you'll additionally have statutory Sale of Goods Act protection for up to 6 years (5 in Scotland), but the claim is against the retailer and not the manufacturer.
Good luck and please take a moment to rate my answer.
My nikon coolpix p530 wont turn on.
I take the SD card out and look at photos with my computer. If the battery is very dead it may not charge in the camera. Nikon cameras have a clock that runs when the camera is off. Fully charging it and leaving it alone for a year will most likely discharge the battery over 50%. If you have an external charger I would try that. When you charge in the camera you are right the power light come on and another light flashes. If you have an Electrical Engineer friend you could ask him/her to put a few volts on the battery to kick it back to life. A too deeply discharged battery may not charge in the camera
Jan 24, 2018 | Nikon Cameras
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
One day i tried to turn on my camera but it wouldn't turn on, my camera is a nikon coolpix s3000. i dont have a memory card and the battery wont charge. its like a block battery it has the...
Please check the voltage on the battery using a multimeter. Now if there is no voltage try and charge and test with the camera , if the camera powers and then shuts off then it is possible that the battery is faulty. If so it must be replaced, check if warranty is applicable.
Aug 08, 2011 | Cameras
When I leave the fully charged battery in the camera for about 10 days it gets completely discharged. This is the original Nikon battery. I though the battery is old and bought a genuine Nikon battery. The...
Does your camera use a compact flash card? I've heard that some Nikon cameras have a problem with the flash card draining power when not in use. Try removing the card when not using and see if the battery lasts longer.
Apr 17, 2010 | Nikon D70s Digital Camera
Why hasn't my Nikon Coolpix L15 ever really worked?
try rechargeble batteries. i switch to rechargeble batteries and they last much longer than regular batteries.
Dec 20, 2008 | Nikon Coolpix L15 Digital Camera
Ah! My camera isn't turning on!
maybe you should try use different batteries, just to see if that's the problem
Aug 08, 2008 | Nikon D40x Digital Camera
Battery Problem
ITS NOT THE BATTERIES -- check out the internet (google "nikon coolpix battery exhausted" and you'll see hundreds of people are experiencing this glitch. best fix i've found so far: remove batteries and memory card, then replace batteries and try again. Maybe firmware update works too, but this fix is not confirmed.
Jun 24, 2008 | Nikon Coolpix L11 Digital Camera
Flashing Low Battery
Let me know if you have a solution...Mine just started doing the same thing
Dec 11, 2007 | Nikon D200 Digital Camera with 18-200mm...
Wont work
Nikon Tech support team may help depending on the age of the camera- there is no economic repair option however.
Jul 01, 2007 | Nikon COOLPIX S9 Digital Camera
Nikon D5000 Digital Camera Logo
220 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
