Question about LG DLE2532W Electric Dryer
I have a LG DLE0332W Electric Dryer. I push the
I have a LG DLE0332W Electric Dryer. I push the button to start and it makes a buzziing sound. I open the dryer and give it a couple of manual turns and close the door quickly and push the button. It will start to buzz and then it catches and starts to turn. After using it for a couple of loads it usually will work. The belt is good..is it the motor?
    Scholar:
  • 32 Answers
Yes, the motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are LG certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide. The motor itself should be under $100.
Best, G
Posted on Aug 03, 2010
I have an LG TROMM DLG and I was having the same problem. A few days ago, I had the " check filter" light come on, checked it, took exhaust hose off, and blew it out (with my leaf blower- maybe not the best tool for the job) dryer worked couple of days and then I had problem you mentioned.
My best friend engineer neighbor came over to look at it. We took top off, turned it on, wouldn't tumble, we gave the drum a push with our hands, it started, we repeated that a coupel of times and now it's working, Seems like belt is fine, motor is ok- maybe something got caught in rollers, Hopefully fixed for good now.
Posted on Aug 05, 2010
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
LG electric dryer model DLEO332W or DLE0332W
Sounds like the belt broke..."loud thump"
Sep 21, 2013 | Dryers
Lg model #dle0332w dryer won't turn open it up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | LG Dryers
DLE0332W--dryer continually runs like its in wrinkle free mode. Will not complete regular dry cycle.
You may have an issue with the control board and it will not shut down once the cycle has been completed. You will need a qualified LG technician to diagnose the problem.
Good luck
Sep 29, 2010 | LG DLE3777 Electric Dryer
Drum won't turn-belt is good-motor
If you can manually turn the drum, the motor's start windings may be bad.
If you can't get the drum to move, check to see if a sock or other small item is stuck between the drum and the inside of the front of the dryer. If you see nothing, it's possible that one or more of the four drum rollers is/are seized.
Jul 15, 2010 | LG DLE2532W Electric Dryer
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
How do I remove the front panel from an LG DLE0332W electric dryer. It is kicking the circuit breaker and I want to check the drum rollers.
Hello alloyd1455,
Please find a link for the service manual for your dryer and note page 26 and up discusses how to open up and gain access to the inside compartment.
Hope this helps
http://136.166.4.200/contents/Laundry/DLE0332/DLE0332_Service_Manual.pdf
Regards,
Rick
Dec 01, 2008 | LG DLE5932W Electric Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Kemore dryer model 96591220
i lovkkekmgkrt,mfgkdgm
trlfdlmgd,mkklr m
frlegtmrkhgm
r,lthntytgm
bgfmlnhjn,fds,ldld.,ddlrfkvbgfd lmmlg
gllf
flgf
fkg
dfkgkmkdff, k,gmh,mghkmkgmkfgmkfgmgkmghkhmgkfmkgmfk,gfm
Feb 12, 2008 | Dryers
LG DLE2532W Electric Dryer Logo
813 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
