Question about Brother DCP 1000 All-In-One Laser Printer
No matter what i do the paper keeps getting jammed before it comes out... It looks like it's getting hang up on something by the front rollers... This is really making me very mad this morning....
  • 268 Answers
I understand your frustration. Try this solution.
* Push down the purple paper lever located on the right side of the multi-purpose sheet feeder and pull the jammed paper upward and out of the feeder.
* Open the scanner cover by pulling the lever located below the control panel, toward you and lifting the cover. Make sure the cover is completely open. Check to see if any paper is left in the paper path.
Close the scanner cover.
Remove the paper in the multi-purpose sheet feeder. Adjust the guides in the sheet feeder to the position for the paper size you are using. Fan the paper well, push down the paper lever. Load the paper with the lever down. Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper (20lb paper) or up to 10 envelopes.
* Turn the power back on.
I hope this helps you.
Posted on Aug 03, 2010
When printing an envelope, the printer says "paper jam" when there is not. We remove the cartridge and toner, clear the message by hitting start and the same thing happens. We try turning the printer off...
Brother paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper.
  • To stop the message, open and close the top most cover of the printer.
  • Lastly, verify the flags and the sensors.
  • If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 22, 2010 | Brother MFC 7840W Printer
Paper jam repeatedly
Possible cause:
The eject rollers get too slippery because of paper dust and other foreign matter.
Recommendation:
Clean the eject rollers with a paper towel dampened with water. A second cleaning may be
necessary. The easiest way to do this (without disassembling the machine for full access to
the rollers) is to hold the dampened paper towel against the rollers and make a blank print.
Clean the rollers as they turn and remove the paper towel as the paper ejects. Repeat as
necessary.
Now is a good time to also clean the paper pick up roller and feed rollers to prevent
feeding problems.
Jun 18, 2009 | Brother HL-2070N Laser Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Paper feeder jams and crinkles the paper up
there is a set of stripper fingers that kiss the fuser roller and paper is jamming up aginst that area
FIX
Open the fuser section door and front door Look at the fuser roller from exit and front door If there is a wiper pad (slides in on a rod from the side of the machine) remove it and put some fuser oil on it
go to area where you find the paper folding up and observe the stripper fingers for any blockage
If there is some bits of toner on the fingers clean them with a q tip and alcohol
take your finger ( make sure machine has cooled and you have unplugged from wall) and press up against the stripper fingers to se if there is movement (some coiers have a solenoid that activates the striper fingers)
The fuser oil hels keep the fuser roller clean and keeps paper from sticking on rollers
Try the copier if this does not fix i believe you have a problem with a solenoid which will require a sevice call
If you want to observe the paper coming through the fuser rollers and seeing if the fingers activate
ou can trip the safety swithes in the doors and exits and observe
Best of luck to you
Jan 06, 2009 | Sharp AL-1642CS Copier
Xerox Workcenter XD125F
Either the feed rollers are dirty or in need of replacing.
Try this first. Take a piece of regular copy paper and on the front in the middle put a small amount or rubbing alcohol on it. IN the middle about 2 inches wide and 2 inched deep. Dampen the paper, do not drench it, and do NOT use a soapy cleaner since the alcohol will not shred the paper. Place that sheet into the feeder and hold the back of the paper, cause it to jam. What that will do is spin the rollers on the alcohol and paper and clean the roller surface. Keep doing that until the paper comes out clean, then allow a couple of minutes for the rollers to dry before running the machine.
If that still doesn't help the rollers will need replaced. Look up, on Google , The Parts Drop, they should show up first. Call them and ask for Britt. Nope its not me and I don't work there, Just deal with them. Excellent people there.
Good luck and let me know please.
Aug 02, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Paper jam problem
Try cleaning the rubber rollers at the front of the printer accessed by removing the paper tray. They will be hanging down from the top of the opening where the paper tray was.
May 29, 2008 | OKI C5200n Laser Printer
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Lexmark Optra C710 keeps on having paper jams
Make sure the rear door is properly seated on it's hinges. Also look for any burs in the plastic guides that the paper might be catching. If you see any burs, try to smooth them out with a nail file or something.
Jan 10, 2008 | Lexmark Optra C710 Laser Printer
Won't print
I'd guess that the machine is unable to pick up the paper so goes into jam mode, paper feed roller is worn, needs screwdrivers and parts.
Here is PARTS also needs little japanesse type fingers, gentleness, then a few bits come off from left side, spring, solenoid, and a couple of gears then tray out, 6 screws release base, few more bits and your done.
You should feed ok from bypass tray still and can have a dodgy attempt at fix by wiping paper feed roller(3cm rubber funny shaped roller sits front centre under with tray out) with something to clean it free of paper dust. ie metho, water.
Nov 03, 2007 | Brother HL 5140 Laser Printer
Paper keeps jamming
My husband and I found that if you hold down the red lever to the left of the paper drawer, you can get the unit to print. Something about the paper roller not coming down to pull the paper into the machine is why it keeps jamming. Good luck
Jul 29, 2006 | Lexmark E232 Laser Printer
Brother DCP 1000 All-In-One Laser Printer Logo
218 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
