My computer started to have this weird noise about 3 weeks ago. when it started it wasnt everyday and I would re start and it would stop. About 4 days ago it started and doesnt stop. Its a constant noise, maybe in the fan, I dont know...
    President:
  • 2,712 Answers
Hello aneleopolski,
It could be that there is something obstructing the fan, as this is the major source for noise from a PC.
If you know how, open the side panel of the PC cabinet and inspect the fan. Make sure the fan grille is not dented or touching the fan in any way. Also make sure that the fan is in an exact upright position, as even a slight tilt can cause the fan to create a noise.
Make sure there are no loose parts in the cabinet, small pieces of plastic, loose screws, etc. Also make sure that when you replace the cabinet panel, there are no wires touching the fan grille. If there are wires running around the fan, try to tape them together and to the panel away from the fan.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 25, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Hello i have a 2002 Honda CR80R 2 stroke Dirt bike and i bought it a couple weeks ago used for my birthday and i was fouling a crap load of plugs and the kick starter wasnt working and the powwer band was...
Kick lever will not start the motorcycle.<br /><br />I can pull it behind a car and it starts.<br /><br />Would it be the Solenoid? THe motorcycle does not have a battery.<br />It is a Beta Trials 260 Zero.<br />The previous owner said he had this problem and I thought that<br />he told me he repladced the solenoid or somethin of that nature.<br /><br />Please help.<br /><input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" />
Jun 29, 2010 | Motorcycles
Check engine code P0410 in 2005 Buick Rainier
Looks like a common problem on lots of GM vehicles. You should watch this video before fixing your problem, which is in the
Secondary Air Injection System:
How to test an electric air pump P0410 case study
Jan 02, 2018 | 2005 Buick Rainier
2002 T&C 3.8, 4 speed auto heavy clutch or brake smell
1st thing to check is when you put in gear when cold and again when hot Take off fast ,,the noise if there igoes up and down with the speed and rpm ,,the noise you can hear mostly is the pump in side the gear box is not pushing enough pressure to the Forward Band clutch which drives the car so it has to slip and that is what you can smell the clutch bands burning And the more you can smell it the worse its getting and soon will let you down in a place you dont want to be..
So get it checked out new or as soon as poss
The A/Con clutch also sounds like its worn out.
Oct 12, 2009 | 2002 Chrysler Town & Country
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
2003 Toyota Corolla 30 amp keep blowing
it sounds like when the cat was changed they have trapped a wire or just moved one over a bit and its rubbing think about what items this 30amp fuse is protecting are any of the items close to the exhaust or around that area, i dont see the aftermarket starter doing this after 2 years hope this is helpful regards JR
May 17, 2009 | 2003 Toyota Corolla
Maytag Performa Bottom Freezer refrigerator making weird noises
This can be due to low supply voltage, causing the compressor thermal overload to trip out. Therefore when this happens the compressor gets hot and it keeps trying to start but fails. It can also be a faulty starter relay, which is located in the conncetion box of the compressor and is very simple to replace.
Mar 20, 2009 | Refrigerators
Weird noise when decelerating
have your exhaust pipe system checked
Nov 20, 2008 | 1999 Saturn SL
Weird display
De-gauss the monitor via Menu 4
Oct 21, 2007 | iiyama Vision Master Pro 510 22" CRT...
Keyboard works then doesn't
take the phone and have it service then if that does not help the issue take it to a mobile service center and have them reflash the keypad with the flash file.
Aug 28, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
