Question about Canon PowerShot A70 Digital Camera
I get a memory card error even though it has a card installed
  • Canon Master
  • 6,826 Answers
Http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
I get a memory card error even though it has a - caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gifI get a memory card error even though it has a - format_menu_1.gif://i.fixya.net/uploads/images/direction_arrow_rt.gif" alt="direction_arrow_rt.gifI get a memory card error even though it has a - format_icon_a70.gifbr />
    Select format_icoI get a memory card error even though it has a - format_menu_2.gif(Format) using direcI get a memory card error even though it has a - direction_arrow_lt.gifss=or direction_arrow_down.gifand press the <SEI get a memory card error even though it has a - format_menu_3.gif
  3. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  4. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Posted on Aug 03, 2010
4 Suggested Answers
SOURCE: no memory card error on canon powershot a400
Maybe you have to format the card before the camera recognizes it
Posted on Jan 13, 2008
VOTIT
  • 2071 Answers
SOURCE: "memory card locked" error message
Just click below desame as your problem;
P { MARGIN: 0px } UL { MARGIN-TOP: 5px; MARGIN-BOTTOM: 5px } OL { MARGIN-TOP: 5px; MARGIN-BOTTOM: 5px } http://www.fixya.com/support/t923762-card_locked
Regards:
VOTIT
Don't forget to rate:
Posted on Jul 07, 2009
  • 44 Answers
SOURCE: It says that my "Memory Card is full" even though
1. Make sure you are saving all your images to what is called the "external" memory, not the tiny internal memory.
2. Format your memory card using the format feature on your camera.
Posted on Mar 08, 2011
Card error
Have you tried a different brand of memory? Not all cards work in all devices, even though they are the same type of memory.
i have had a situation where i bought memory on sale, but would not work. When i replaced it with a different make, ie: Kingston memory, it was recognized.
Aug 06, 2014 | Intova Sport HD II Waterproof Action...
Photosmart memory card error
What type and size memory card? The PSC1350 won't work with SDHC cards even though they fit into the slot.
Dec 27, 2013 | HP PSC 2410 All-In-One InkJet Printer
MEMORY ERROR on the screen even
Keep in mind tha compabilitie memory card for this camera. Try formating your memory card.
Aug 22, 2012 | Canon PowerShot SD4500 IS Digital Camera
Unrecognized file type error when transferring .avi files from memory card to computer
printer usb connectivity may jam with avis better to plug card reader direct into usb ports on pc just a suggestion.
Apr 30, 2012 | SanDisk 2GB Secure Digital Memory Card
When iput my sd card in my camera it says card locked even though the card isnt locked what can i try
There are several possible causes for "memory card locked", "memory card error", or "no memory card". If moving the tiny slide switch on the card didn't help, see other troubleshooting steps for this problem listed here.
Sep 03, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
SD memory card and cell phone problems
To my knowledge, razr's can not handle a 4gb card.  I believe 2GB is the highest.
Mar 06, 2009 | SanDisk 4GB microSD High Capacity Memory...
Olympus D-435 digital camera, when you turn it on, error msg says "battery empty" then times out and shuts off. New Batteries have been installed, did not correct the problem. How can I make...
If ur using a memory card try to use a memory card even though it relates the battery it may be a memory card problem....
First take out the memory card and then try to use the camera and if it works fine that says that there is a problem with memory card if not Call 800-622-6372 and get the camera replaced if it is out of warranty
Oct 17, 2008 | Cameras
Memory card error
Dear jk_cibergirl:
It is likely that some type of corruption has happened to your memory card. Try reformatting the card in your camera to correct any problems. If that works then you should be fine to take more pictures from this point. If not, you may need to get another memory card. Check your memory card manufacturer for warranty information.
Just a few tips to help you avoid this problem in the future:
1. Even though your computer can format a memory card, do
not ever do so from your PC. Your computer lays down a
different type of file table than your camera, which can lead
to data corruption.
2. Always format the memory card in the camera it will be
used in after each downloading session AND even when
using a brand new card right out of the box for the first time.
3. Do not share cards among cameras - even if they use the
same type of card - even if they are the same camera model!
Consider your memory card to be camera specific.
4. Do not place your camera close to strong magnetic fields
(e.g on top of a television)
5. Lastly, even though your camera has a single image erase
button, do not do what some do and fill your card up and then
go into the playback mode and erase a few images just to
take a few more new images. This almost certainly will lead
to data corruption on your card. Download your images and
reformat the card to take additional shots.
If you need to recover any lost images from that memory card, you can give it a try by simply downloading free software from the internet (such as Zero Assumption software available at www.z-a-recovery.com), connecting your memory card to your computer via a card reader, and running the program on the card reader volume.
Hope this helps.
Sincerely,
HeavyDLB
May 28, 2008 | Canon PowerShot A520 Digital Camera
No memory card error on canon powershot a400
Dec 04, 2006 | Canon PowerShot A400 Digital Camera
Canon PowerShot A70 Digital Camera Logo
312 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
