Re: Shure BG 4.1 microphone I need to solder the wires coming from the microphone cartridge to the XLR male in the base of this hand-held mic. There are three wires....Green, Brown and White. Which color goes to which pin?
1=white 2=green 3=brown
Posted on Oct 25, 2009
  • rajivsanchez Oct 25, 2009
    While the white, green and brown wires were still in place, I have another wire in the shaft of the microphone. A black one, this comes from the minus side of the battery compartment and is hanging loose. I do not know where this wire is supposed to connect to, so if you read my answer, although more than a year later, please check if you have a black wire in there as well and where it connects to.
    Thanks
  • Buss154 Feb 18, 2011
    It connects to the same pin that the white wire goes into.
My microphone has has disconected from the plug, how do i fix it,the wire
It can be replaced, but if you are not used to a solder iron, I'd recomend buying a new cable off the shelf. Either female XLR to male XLR or Female Xlr to TS (large 1/4inch jack) depending on what you wish to plug into
Sep 07, 2011 | Shure SM58 Professional Microphone
The inside (3 pin input) came out of my microphone when i was takeing out a leed and ive lost the part?
Go to your local pro audio store(or good seller on ebay) and buy an new male xlr connector, the insert should fit the mic,
wiring will be to pins 2 and 3
ground is picked by the fixing screw
This is assuming you can solder, if not then take the mic to your audio store/repair shop.
Hope this helps,thanks for using FixYa
Vote for this if you like it.
Nov 22, 2010 | Shure BETA 87C Professional Microphone
How many wires should be going from on/off switch on Shure BG 1.1 to the base connector
I think there should be two wires that go from switch to the XLR connector, a blue and yellow wire.
Jun 02, 2010 | Shure BG 1.1 Consumer Microphone
Shure 58 when plug it has no sound
First i would check the cable. If cable seems good I would buy some contact cleaner and try cleaning the xlr pins on the bottom of the mic. Last i would take the set screw out of the side of the mic and carefully remove the xlr assembly. There are 2 wires connected to that and not a whole lot of slack so be careful. Basically make sure they are still soldered on.
Mar 27, 2010 | Shure Beta 58 Microphone
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
Where can i get my shure beta 58 repaired? I live in Redditch in the UK.
The easiest way to find a service agent near you for your microphone is to contact Shure at the following;
All service and repair issues for Shure, QSC, Phonic, Sound Devices and Radial products are handled directly by Shure Distribution UK. Please contact them at the following for information on service and repair issues:
Unit 2
The I.O. Centre
Lea Road
Waltham Abbey
EN91AS
Phone: 44(0) 1992 703058
Fax: 44(0) 1992 703057
email service@shuredistribution.co.uk
Hope this helps. Please remember to rate my answer.
Many Thanks
Jul 13, 2009 | Shure Beta 58A Professional Microphone
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Shure SM57 Wire broken off
On the XLR end, you should see a small screw hole. This screw is reverse threaded. In other words to make it go into the mic, you need to turn it counter-clockwise. Once that screw is inside the shaft, the XLR connector should come out. You may need to pull it out using needle-nose pliers. Pull carefully so you don't break the wires.
Dan
Oct 06, 2008 | Shure SM57-LC Professional Microphone
299 people viewed this question
 Grubhead
Grubhead
