Question about Toys
Need wiring diagram for Graco Swing. Swing not working
3 Suggested Answers
  • 286 Answers
SOURCE: Need instructions for Graco-Windsor 6-speed
hi
i think these are correct
http://download.gracobaby.com/ProductInstructionManuals/ISPS030AA_ISPS032AA.pdf
Posted on Oct 24, 2010
SOURCE: i need instruction manual for
you better click this site..:
http://www.gracobaby.com/CustomerService/ProductInstructions/Pages/default.aspx?page=ProdInst
and choose which is the model that you possess.. :)
have a nice day ahead! ^_^
Posted on Feb 07, 2011
How do you turn off a graco open top swing?
www.gracobaby.com/instruction%20manuals/archive/152.pdf
GracoTo add time, push the time button once or twice. To turn swing off, press and hold either speed button briefly.
Jan 08, 2016 | Baby Gear
Graco swing
I'm not sure if you tried a different outlet plug yet, but I would try to eliminate whether if its the power source (outlet) or the swing itself. Also, if the outlet has a reset/test buttons on it, then it might have tripped itself.
Apr 23, 2013 | Baby Care
We need the base to a Graco Sweetpeace baby swing.
Under the "Add your solution or ask for clarification" window click on the camera icon to add photo.
May 25, 2012 | Graco Sweetpeace Newborn Soothing Swing...
How to disassemble graco swing
First, take part the seat. It had buttons and what not so undo them and take it off the frame. 2nd: Take the mobile (where the teddies hang) part by pulling. From there you just pull things apart. You shouldn't need any tools.
I hope this helps a little.
Apr 27, 2012 | Graco Lovin Hug Swing - Erin
There a bar that came off the swing that I have. Just using for the first time it was given to me by some one so it does not have instructions. So can u pleaseeeeeeee help me and tell me where the bar is...
Most of the time if you go to Graco's website they have manuals for these type of items. I had to do it for my new Fisherprice swing. If you can not find it there call them and they will send you one. I had to do that before too.
Jul 08, 2011 | Graco Winnie the Pooh Swyngomatic Infant...
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Same problema as described by other person: Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Oct 19, 2010 | Graco Toys
Graco swing not working, I'm trying to open the motor box, but can't get the last screw out, which is behind the swinging attachement.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Nov 15, 2009 | Graco Baby Gear
Toys Logo
251 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
