Question about HP LaserJet 3600n Printer
My hp laserjet CP 3505n is not printing the error is 10.92.03 cartridges not engaged
  • 319 Answers
Www.fixya.com/.../cartridges_not_engaged_error_10_92_03_hp_3800n
Posted on Aug 03, 2010
It displays either code 59.51 or10.92.02 not engadged
It's likely either a bad Cyan cartridge or ribbon cable pinched. This is what I found on DepotTechSupport (so the solution isn't mine, just the searching) :-)
59.51, 59.61 ERROR
http://depottechsupport.com/index.php?/Troubleshooter/Step/View/8
59.51 ERROR 59.61 ERROR An error occurred with the cyan printcartridge drive motor during startup or rotation. 1. Check that connectors J5004 on the cyan print-cartridge drive motor and J207 on the driver PCA are seated correctly. 2. Replace the cyan print-cartridge drive motor. 3. Replace the driver PCA
10.92.YY CARTRIDGES NOT ENGAGED
10.92.YY CARTRIDGES NOT ENGAGED The print cartridges are not engaged correctly. YY Description: 00 Black 01 Cyan 02 Magenta 03 Yellow 1. Open and then close the front door. 2. Make sure all the print cartridges are seated correctly. 3. Turn the printer off and then on. 4. Inspect each cartridge lock-lever (on the right side). Open the front door and remove all cartridges and the ETB. Then use the ETB holder on the right side to move the lock-levers up and down. Replace the cartridge lock if it is broken. 5. Inspect the right side cam. This piece controls the movement of the cartridge engagement arm, the cartridge shutters, and the OPC drive. You can inspect this piece without taking off the covers by wiggling the white rod arm on the right side of the ETB. If it moves easily, the part is broken and should be replaced. 6. Inspect the ribbon cables. Folded or damaged ribbon cables can cause a short that generates an error. 7. Inspect the cartridge guide rails to see if any are damaged. 8. Upgrade the DC controller firmware. 9. Clean the contacts on the memorycontroller PCA. 10. Verify that contact is being made with the E-label PCA on the print cartridge. Replace the print cartridge if the Elabel PCA is missing. 11. On the DC controller, make sure that connectors J1022 and J1023 are seated correctly. On the driver PCA, make sure that connectors J201 and J401 are seated correctly. 12. Check the gears on the print-cartridge drive motors. Replace defective motors.
Sep 09, 2013 | HP COLOR LASERJET CP 3505 N PRINTER
My hp color lasejet cp 3505n show the follow message at the boot "INFLATE FAILURE SEND RFU UPGRADE" and nothing dont work
This error message occurs when there is an internal hard ware failure. Please send the unti in for repairing it.
Thanks and Regards,
Dr Tony
May 04, 2011 | HP LaserJet CP3505n Printer
Downld file now SEND RFU UPGRADE ON USB DEV PORT
install printer Driver
change print port to "Virtual printer port for usb"
use usb line
down load the right firmware .rfu file
in CMD mode,type:
copy /b firmwarefilename.rfu \\pc name\printer name
waitting
it will be down
good luck!
Nov 26, 2010 | HP LaserJet 4345mfp Printer
192.168.1.65 trouble code on an HP 3505n printer
192.168.1.65 might be the ip address of the printer and not a trouble code.
Sep 11, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
Problem in hp cp 2025 color laser printer that printer is giving error message "used black cartridge is in use error
This error typically indicates that the cartridge was moved (e.g. previously installed) from another printer to your printer. The error should not affect your ability to print. If you want to clear the error, replace the affected cartridge with a genuine HP replacement.
Aug 10, 2010 | HP laserjet Cp2025dn color Card Printer
Close top cover error hp 3505n
just check your user manual, or simply download it from hp.com
Apr 02, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
10.92.00 cartridges not engaged error on Color Laserjet 3500. Replaced black cartridge. What should be my next step
check the contacts on the transfer unit, or replace the transfer unit. could also be the dc controller or the high voltage power supply pcb.
Aug 11, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
HP LaserJet 3600n Printer Logo
793 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
