Question about Amana NED7200TW Electric Dryer
Hi, I think I need a new motor. When I push on the start switch, I hear a hum, but the motor doesn't start up. However, sometimes it does start. However, sometimes after running for a few minutes, it stops and then, when I push the start switch, I don't hear the hum, nor does it start. Is there a startup circuit in this dryer, or is it most likely the motor and where it lands in its rotation after shutdown?
    Novelist:
  • 127 Answers
Something could be lodged in the blower wheel, or otherwise jammed up the unit, ie; rollers, idler wheel.
either way something has caused your motor to work harder than it was designed to, or it has just gone bad.
there is a thermal switch within the motor to shut it off if it gets to hot. that is likely the reason it shuts off after a little while and when it cools down will restart.
there is also the chance that your push to start button has gone bad, but highly unlikely.
either way it will require tearing down to find the problem.
best of luck, have fun
Posted on Aug 03, 2010
  • Amana Master
  • 1,527 Answers
Hello check the capacitor next to the motor this this starts the motor up
I have a Kenmore elite washing machine and when I power it on it goes on . then I push the start button and I hear a humming noise and the timer is flashing . Please help.
oh oh a humming noise usually not a good sign, and usually is from a bad motor with windings that have gone out. in ur case u may be hearing what u think is a humming noise? but in reality may be a bad push start button which can sound like a hum but is more of a buzzing sound
Feb 19, 2015 | Kenmore Washing Machines
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
Compressor runs and compress air,but when air setting is depleted compressor will not start to compress more air.If you waite it will start some times do think this might the compressor switch
If it doesn't try to start, then it could be the pressure switch. Another suspect could be the thermal overload on the motor. The motor (or just the overload) might be overheating and shutting the unit off, then allowing it to restart when it cools.
Is there any humming, or does it blow the breaker? When ot shuts off, do you hear a brief hiss of air?
If there is humming or breaker blowing on restart, or no hiss of air at shutoff, the pressure switch unloader valve is probably bad. If the air blows off, and there is no humming, and the compressor doesn't reliably start, it is probably the pressure switch. If pressure drops too low, give the pressure switch a tap with a screwdriver. If it starts then, the pressure switch is your problem.
Jun 02, 2011 | Air Tools & Compressors
Actually ours is a Princess II made by Filter Queen, purchased in 1987. Wondering if motor going bad because when switch on sometimes it starts fine but other times you have to push the switch several...
It sounds like it's probably the switch. It could also be loose wiring connection to the switch, which can result in sparking. This presents a fire and/or shock hazard. Don't use it until you get it repaired. I do recommend having the vacuum checked out for a definite diagnosis. You're right about it possibly needing a new motor.
Mar 30, 2011 | Filter Queen Majestic Canister Vacuum
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
Frigidaire dryer hums when button is pushed in but won't start
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Oct 19, 2009 | Frigidaire Electric Dryer
Hum but wont start
The slight hum you are hearing is the start windings in the motor. This is a common problem in the kenmore dryers and there is nothing you could have done to keep it from happening. the part number on the motor is 279827 and price from sears is $105.99.
Oct 03, 2009 | Kenmore Dryers
Start problem
Hi,If you hear the hum while you are pushing the start button and when you let off the button the hum stops, you have a notor going bad.
If you can get someone to help you, open the door, hold the door switch in, while someone else holds the start button, you try and turn the drum with your other hand. Sometimes the motor will start but, this only confirms the motor is bad and needs replaced. I hope this helps.
Thanks
Vic
May 15, 2009 | Dryers
Amana NED7200TW Electric Dryer Logo
211 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
