Question about Goodman CLQ36AR49 Air Conditioner
Outside unit is not turning on, breaker keeps flipping, What should I check next?
  • Goodman Master
  • 8,220 Answers
The first thing to look for is a swollen shorted capacitor.outside unit is not turning - 4c1711d.jpgCheck the compressor next, look for a broken wire, compressor terminal shorted to frame or a bad overload.4e87185.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 03, 2010
Not cooling
are you talking about a central a/c system? the fan that blows is the indoor air fan? check breakers for outside unit. one breaker in the house panel box and a breaker at the outside unit. because other wise tha cap or contactor (for the outside unit) may be bad. both of witch may keep unit from turning on. unless you are knowledgeable about electricity I would not recommend opening the outdoor unit. you could get electrocuted. safety first
Oct 11, 2015 | Heating & Cooling
I flipped the main breaker in my house and when I flipped it back my unit wont come on what cN I do?
Check the emergency shut off that is outside the house next to the condensing unit.
Jul 20, 2015 | Heating & Cooling
Outside ac unit breakers keeps breaking
Check all wiring for loose connections, particularly at contactor. Check for short circuit and earth leakage
Apr 21, 2012 | Heating & Cooling
I have a question about a Carrier Air conditioner. It's an outside unit and it's old. When I turn the air on the air blows from the inside heater/air unit upstairs in the wall. Outside the air con ...
Could be just a blown fuse or circuit breaker. Fuses are generally located close to the unit in a small box on the side of the house. You will have to flip the box open to find the fuses. It may have a cartridge you have to pull out. Fuses are not visibly bad, you have to check them with an ohm meter or sometimes a hardware store can check them for you. Otherwise you will have to buy two and just replace them both.
The circuit breakers are usually in the house along with all the other breakers in a main panel. There will be two breakers and will probably be visibly tripped. Just flip them all the way back and forward to reset
Aug 03, 2011 | Goodman CKL49AR49 Air Conditioner
Outside hvac unit
Check the breakers at the main panel flip them all the way off and back on. If this doesn't help check the outside breakers or diconnects near the units for power. Some disconnects have fuses or breakers so you may need to check these for power also.
Jul 29, 2010 | Ruud UBHC Air Conditioner
Air conditioner keeps flipping the breaker
Could be a lot of things. About the only thing you can do besides calling a service tech is to 'make sure your coil on the condenser (outside) is clean. This coil can be cleaned with a water hose, but you need to make sure you have all electricity turned off.
Turn off the breaker on the outside unit (this could be a fuse block that you have to pull out) and make sure you have your inside thermostat in the off position.
Once you are 'absolutely sure' that you have all electricity off - you can wash the coil with a high pressure hose. Just make sure that both - the inside and outside of the coil is clean; you may have to disassemble the unit a little bit, i.e. take the top off or one of the sides, etc.
The only hope you have - is that the coil is clogged and causing the compressor to overheat and go off on amp overload. It's possible this is the case - but I also suspect the compressor is electrically breaking down which is not connected to the condenser coil being dirty, in which case you will need a service tech and may be faced with some expensive repair. Let's hope this is not the case.
So - it's worth a shot to wash the outside coil.
Not to be 100% negative - it's possible it's something minor and when a service tech looks at it - it could be a fairly cheap repair bill.
Good Luck!
May 02, 2010 | Ruud UBHC Air Conditioner
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Outside unit tripped the breaker. flip the breaker
Check the fan relay or contacts first. If the compressor comes on then your fan may be locked and will need replacing.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
A/c unit outside will not come on.
More than likely, your AC unit is on it's own breaker inside or outside the house. If it is, it is very possible that the breaker is either flipped or blown. This is a problem I would HIGHLY recommend that you contact a professional for due to the nature. If you flip the breaker back on, you could cause a surge to the unit, thus "frying" it, or it could cause a fire inside/outside the home.
Apr 27, 2009 | Carrier Heating & Cooling
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
70 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
