My kubik digital mp3 player freezes at the main screen have tried resetting to no avail. Any suggestions?
Make sure you have reduced the resolution to 320 by 180. If you haven't done this you may get what I did... it starts to load and then freezes with 3 dots on the screen. Mine now works fine. :)
Posted on Aug 20, 2010
How do I fix my Kubik Evo 8Gb? The software doesn't work. The screen is black and I can not get access to the menu. My files are ok I can see them when I plug it to my computer. Thank you
Your electronics are ng. U might try to reset unit by doing a hard reset to see if that clears up the anomaly. If not, replacement, not repair, is in order.
Aug 27, 2016 | Kubik Digital Electronics Kubik Evo 8Gb...
Wont turn on when not plugged in. but will turn on if charg plug is plugged in and you turn on the power switch and unplug the charger it will stay on but wont play, keeps coming up format error.
Customer Reviews: Kubik Evo 8GB MP3 Player with Radio ...
www.amazon.com/Kubik-Player.../B0041MMMWW
Amazon.com, Inc.Find helpful customer reviews and review ratings for Kubik Evo 8GB MP3 Player with ... Con's - Wonder if some of these items can be fixed with a firmware update. ... Just push the main button (or any button) and it will turn on and function as usual. ... 2) Play while plugged in charging works with the wall charger, but still NOT ...
Evo won't charge via USB ' Android Forums
androidforums.com > Android Phones > HTC EVO 4G
Jun 29, 2010 - Whenever I plug in my Evo, I select Charge Only (or if I do nothing, it selects Charge. ... If I turn off my Evo it charges from the USB fine. ... Check your computer's stats... what does it say about its USB status when your Evo is plugged in or ... I had a problem a while back where it would charge via USB, but not ...
Dec 29, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
I need the driver for my kubik evo 8g mp3 player. The driver disappeared off my computer and now doesn't recognize my player.
You should not need drivers for this device as it ought to be picked up automatically by your computer (assuming that it's Windows, what version are you running?). If you have an expansion card in the player, then try removing this and then re-connecting the Kubik to your PC to make sure that the expansion card is not faulty.
Another quick test is to check the cable, both in a different USB slot if you have one available and / or by connecting another USB device that uses the same connection (in my case, a digital SLR camera has the same USB adapater so I can use the cable for either). If, doing this, the second device also is not recognised then try swapping the cable for a new one (but again, if possible test the cable and connection to other USB device in another USB slot as well).
One other quick question - does the Kubik device work still when unplugged from he PC?
Feb 17, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
How to put a playlist on a kubik evo
Try rebuilding the Music Index using the option under the Music Menu when the device is powered on
Apr 12, 2014 | Kubik Digital Electronics Kubik Evo 8Gb...
I have converted a film to the correct avi format/size/bitrate/audio..etc etc and tried every configuration and even contacted kubik. the film will not play due to unrecognised format
You can install the software off the Kubik site
AVI Converter Kubik Digital and this has the advantage of being set to the correct size for output (160x128) but I have had mixed success with this. Some files have worked fine, others just stall and the batch processing feature does not appear to work (at least for me) so I am searching for more reliable alternatives.
Oct 29, 2013 | Kubik Digital Electronics Kubik Evo 8Gb...
My Kubik edge 4GB won't turn on. It just keeps freezing when the words 'Kubik Digital' come on the screen when I turn it on. How can I make it work again?
Thank you for your enquiry I will be glad to assist you. Please can you make sure the player has been reset correctly. There is a reset button on the side of the player please can you press this button carefully using a pin when the player is turned on. The actual reset button is at the bottom of the hole and you will hear a faint click when the button is pressed correctly.
Please drain the battery completely and reformat your player?
To Format the player follow these instruction:
  1. Connect the player to your computer using the USB lead
  2. 2. Go to “My Computer”, your player will be shown as a Removable disk
  3. 3. Right click on this icon and select Format.
  4. 4. All files and folders will be deleted from the player
  5. 5. Once the format is complete, disconnect the player from the computer and turn the player off.
Please let me know if the problem persists.
Amy Jackson
Customer Services
Kubik Digital
www.kubik-digital.com
Mar 27, 2010 | Audio Players & Recorders
Kubik Edge 4gb 'frozen' screen on boot up.
Hey guys, I'm gonna cut to the chase, the little hole on the bottom right hand corner or the kubik edge get a sewing needle and press it 2 times! Hope it works guy xxx
Mar 08, 2010 | Audio Players & Recorders
Kubik edge
I have a touch screen Kubik player It was stucked , What I want to do now.
Jul 27, 2009 | Audio Players & Recorders
362 people viewed this question
 Grubhead
Grubhead
