Question about Ricoh Office Equipment & Supplies
We had an storm here last night and now we are getting this message: If Error reoccour Call service, SC 545, Power Off On
  • tommyb662 Aug 03, 2010
    I removed the fuser unit and reinstalled it but that did not work. I had just bought and replaced this fuser unit about 2 months ago.
    Sorry, I called the 800 number and they walked me thru a reset....it's working fine now. I'm glad I called them since it only took about 1 minute to reset and it didn't cost me a thing.
  • Ricoh Master
  • 4,737 Answers
For Ricoh machines, this error code "sc 545" refers to overheating problem. In most cases, only opening and removing the fuser unit and reinstalling it fix this problem. So I would suggest you to do this as first option.
If the above method isn't helpful, your options are to replace the thermistors on the Fusing Unit and or to replace the whole Fusing Unit (Fuser). the error message simply means, you need to call a tech so that he/she can repair it for you. If you know what thermistors are, how to disassemble the machine or how to dismantle the fuser, you can do it, but I wouldn't recommend that if you are not good with these things. You may damage it further instead of repairing it. If repairing once is failed, most tech will charge you higher fee and will take more time.
If you have problem calling a ricoh tech, better replace the fuser unit, most of the times, this saves time and money. You'll need to pay only for the unit and delivery (if applicable). But if you call a tech, you'll pay for both the parts and service charge.
Good luck.
Thanks for using FixYa.
Posted on Aug 03, 2010
  • Lebanon Raingam
    Lebanon Raingam Aug 03, 2010
    Thanks, and it's good that you have tried my instructions. But it seems you didn't replace the thermistors yet. At this situation, the most important thing is to replace the thermistors if you are not ready yet to replace the fuser unit. We should understand that since it's only a machine, even if i replace today, it can fail tomorrow or next week or next month, no one knows. But if we can fix it in a simpler way, like replacing a part or removing a part, that's the best and in most cases, repaired unit works longer than even new and expensive unit.
    You can also try removing the fuser and power on the machine, if the error message shows up on the screen even without the Fuser, then no need to work around with the Fuser, better directly call for service.
    Even replacing the thermistors don't help, your only chance is to replace the fuser. If you still have another old or new with working condition, you can try to make sure the problem is with the fuser.
    I wish you Good Luck.
  • Lebanon Raingam
    Ok.. good to hear that you've fixed it at last..
    Thanks once again.
RICOH AFICIO SP 4210N SERVICE MODE SC 545 Power Off On How Solve it this error?
SC545 fusing lamp remains on. reset fuser error in service mode. If it still reoccurs. Possible bad thermistor or power supply board. To go to service mode press up and down botton for about 5 sec and then press enter. In service mode engine fuser reset SP5810 execute
Sep 30, 2017 | Ricoh Office Equipment & Supplies
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
I am consistently getting a jvm 545 error on my blackberry storm 9530
I PUT THE BATTERY IN IT LOADS AND THEN STOPS A QUATER LEFT AND TURNS WHITE AND SAYS JVMERROR 545 HELP ME NOW PLEASE
Feb 09, 2011 | RIM BlackBerry Storm 9530 Smartphone
Sc 545-00
SC545: Fusing overheat error 2
-Definition- [A]
The fusing lamp stays on at full power for 30 seconds while in the stand-by
condition after warming-up is completed.
- Possible causes -
· Fusing thermistor out of position
check/clean the thermistors
and ull need a service engineer to reset the code
Nov 25, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio AP400N Laser Printer Sc 545 off on error
SC 545
A Fusing lamp stays on
The fusing lamp stays on more than
12 seconds after the main motor has
been turned off.
• Fusing thermistor defective
• Power supply board defective
• Defective connection of the fusing
This will not reset by turning of/on must enter sp modes to clear this error.
Due to possibility of fire hazard would be best to have tech look at it
Oct 09, 2009 | Ricoh Aficio AP400N Laser Printer
Error Box on Scree with Error SC-545
Hello sir; According your message, I guess your copier should be Ricoh, any way need to reset your machine, just follow following steps;
1, press "clear mode", "107", and hold down "clear/stop" key until screen change message.
2, turn power off and back on,machine should be in working now.
May 29, 2009 | Ricoh Office Equipment & Supplies
Power outage last night. Deleted all saved voicemail messages. when turned on - machine says "no massages" How do I retrieve lost messages?
I'm sorry there isn't. Answering machines like this have very little ROM memory. After a powersurge and outage like last night, it wiped the whole memory chip. You can try there support page. It's actually pretty good. http://telephones.att.com/telephones_ui/support/index.cfm
Jun 28, 2007 | Lucent 1872 Corded Phone
78 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
