Question about Nintendo Wii Console
My console still works, but will not show the picture. I have unplugged it, tried a different output and it still doesn't work
  • 1,527 Answers
Hello try another lead or if you've got friend with a wii try it on there tv first if it still don't work get back to me and i'll try something else
good luck
regards
shaun
Posted on Aug 03, 2010
Problem with my LG TV and my XBOX360 , there no picture and sound when i connect my xbox with hd cable.
Try different AV ports on the TV, if it doesn't work press the right trigger + Y, right after the console starts (this will reset the resolution of the console output) I'm assuming you are using the same cable that worked with another TV, so neither the cable is broken, neither the Xbox. It can only be an output format problem, bad configured or a faulty TV.
Jun 09, 2012 | Microsoft Xbox 360 Elite Console
My problem is earlier today i was playing my ps3, the picture was showing on the t.v. ( a HDMI Cable conected it to the tv), but 30 minutes later, i tried to play my ps3, the picture was not showing up...
Sounds like your video settings are wrong. Since you were on the HDMI connection the video was outputting in HD. When you switched over to normal AV (composite) cables the video was still outputting in HD.
Simple fix: power off your PS3 (so it's in standby; red light is showing). Then turn it back on, using the power button on the console (not the PS3 controller) and hold down the power button until it beeps a second time (about 5 seconds). The video settings will reset to composite. If needed, change your video settings.
Normally I'd put down like 3 other things it could be (each worse than the last), but I'm fairly certain that this will fix it. If it doesn't, just say so and I have many a more potential fix available.
Hope it works!
Sep 24, 2011 | Sony Playstation 3 (PS3) Console
When my xbox is plugged in ether by components or av all i get is mode not surported???
If you are using one of the older models of the Xbox 360, not the one of the "Slim" versions, make sure that the switch at the base of the Component/AV cable where it plugs into the Xbox is on the right correct output. If this doesn't work it is most likely a problem with the TV settings. Try using it on a different TV and see if that works.
If this doesn't work give me some more information and I'll try to help you out.
Apr 30, 2011 | Microsoft Xbox 360 Console
My playstation wont show up on my tv the audio is working but i get no picture can someone help me please
you can try a different tv, different channel and try different console-to-tv cables too, if that doesn't work you might have a problem with te actual console...
Oct 05, 2010 | Sony Playstation 3 (PS3) Console
Everything connected, the screen shows but the
Try connecting the PS3 to your TV through a different port. For example, if you are using HDMI1 on your PS3, try HDMI2 or HDMI3.
Try a different cable. If you have a friend with a working cable try that.
Try a different output on the PS3. For example, if you are currently using the HDMI port, see if the standard composite or component output will work.
While convenient to plug things into an AV reciever, I find that just adds another link in the chain of devices that could go wrong.
Good luck.
Jul 14, 2010 | Sony Playstation 3 (PS3) Console
Ps3 has black screen with white lines some noises
I am sorry but the voltage surge, which must have occured after having switched off the protector has most probably blown or fried the High Voltage circuitry which makes the tube function. It could be that both horizontal & vertical control IC's are damaged. If the picture tube is still OK then its worth repairing. However if the picture tube is gone then better to buy a new diplay unit after checking up the rest of the equipment that a playstation consists off......................................sodeep
Aug 09, 2009 | Sony Video Game Consoles & Games
My wii wont turn on the power does not show a light
Try a different outlet to make sure the outlet you have it on is good or not.
If a different outlet didn't make it turn on then at that point, try another ac adapter for the Wii. If a different adapter doesn't work then you know the main board inside of the Wii is bad.
Aug 08, 2009 | Nintendo Wii Console
Console showing one red light and screen says system error e 74
That is a Video Output error. Check your HD AV cable connections. Unplug and replug them back in. You can also try to replace your video cord. If that does not work then there is a internal error with the video output device.
Sep 24, 2008 | Video Game Consoles & Games
Av output cord does not work Ive tried two different cables, neither work. Initailly the picture was off so I wiggled and or tightened cable to console and that worked. At last attempt the picture was...
your video card probably overheated and blew up. (not that uncommon, even in computers) you will need a new ps3 because the video card is part of the ps3 board.
Aug 08, 2008 | Sony Playstation 3 (PS3) Console
Nintendo Wii Console Logo
120 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
