Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Plastic dishes and utensils have white film on them
We have used a rinse aid, but all the plastic utensils (spatulas etc) have white film on them when they are done
  • KitchenAid Master
  • 43,501 Answers
Check your heating element..
Dishwasherplastic dishes and utensils have white film on the - 2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 03, 2010
I have the same issue to the point where pans (that have been in a dishwasher for years) now are permanently "white filmed" on handles, all my cooking utensils are the same way, and my glasses...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 27, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
White powdery film building up on dishes. Especially noticeable on plastic glasses/utensils. I keep the Jet Dry reservoir filled. This is a new problem on a mature dishwasher. Why is this starting to...
It sounds like you may be using too much rinse aid or have changed from a detergent based tablet to an all-in-one type.
Reduce the amount of rinse aid in your wash by altering the setting on the rinse aid dispenser - usually a dial numbered 1-6. Lower the setting and see if this helps
Jan 25, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool dishwasher leaves white coating on plastic utensils like spatulas etcwhen finished washing. It also doesn't seem to clean a glasses and dishes as well as it used to. dishwasher is about 8years...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Aug 15, 2010 | Whirlpool Dishwashers
Maytag DWU8330AAX: glasses, plates, utensils,
The rinse cycle is the same as the wash except the wash uses detergent and the rinse uses rinse aid.
The rinse cycle will dispense rinse aid if you have filled the dispenser. Check this first, that would be the most likely cause. Also in the spring as the water table table in most cities begins to rise the water quality goes down, extra calcium in the water can cause this problem.
Here is a link to help understand that. Let me know if you have questions.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
May 02, 2010 | Dishwashers
White film on inside of dishwasher on racks and dishes, plasticq
There will adjustment in the respective compartments for reducing or increasing the detergents. Adjust this. Refer manual. Finally have a look at the inlet water quality for excessive calcium!
Apr 15, 2010 | Bosch SHU5315UC Dishwasher
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
I have a white film left on the dishes i've had this dishwasher for about 4 years and this just started
Place a cup of vinegar in top rack corner (upright) and run an empty cycle to clean any build up.
Stop using any rinse-aid (jet-dry etc.), if the detergent you're using already has it included. Too much rinse-aid can create a white film on your dishes. A good way to check for rinse-aid build up is to run your fingers on the inside of the cabinet and check for a white powdery residue on your fingers. You can also run the dishwasher for a couple of minutes and check for excess suds in the water when you open it. Excess suds would indicate a rinse-aid build up.
Run the hot water at the tap before starting the cycle and make sure it's at the recommended temperature (120-140°F).
Mar 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Motor and pump replaced still not getting dishes clean
Film on dishes
the problem is hard water. this is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Oct 28, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
374 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
