Question about Brother Office Equipment & Supplies
How to change Baud rate on MFC-8640D - Brother Office Equipment & Supplies
2 identical fax machines cannot communicate at 2 differant locations about 30 miles apart. the machines operate properly faxing anywhere else. DSL has been taken off the line at one location and the fax line has been fed from a differant location as well on good clean testing cable pair
Posted on Feb 05, 2010
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
How can I scan files to pdf using Brother MFC-8640D
You will need to open the control center program which is installed when you install the printer on your computer.
Start, all programs, Brother, control center. Click on configuration then scan then file (or which ever you normally scan to). There are two tabs at the top, change the file type at top of each tab to pdf and press ok.
Jul 03, 2010 | Brother MFC-8640D Printer
I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Jan 15, 2010 | Brother MFC-8640D Printer
I have a Brother mFC 8640D - paper feeds through
The black exit rollers on top get slick from the paper and toner, they need to be cleaned with a damp rag. You hold the rag against them 1 at a time and open and close the front door so they will rotate while you hold the rag on them. Should help the paper exit.
Oct 02, 2009 | Brother MFC-8640D All-In-One Laser Printer
I need to change a baud rate to9600 for telephone line. can you direct me please.
How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
I have brother MFC-8640D printer How can i get the software
From the manufacturer website! :-)
http://www.brother.com/html/download/index.htm
go to the search box and put your model no. in....
Jan 28, 2009 | Brother MFC-8640D Printer
MFC 8440D FAX VOIP
You should change the Baud rate to 9600 on the machine. This should correct your issue.
Also call vonage and they have some settings they can modify to improve performance.
Mar 31, 2008 | Brother MFC-8840D All-In-One Laser Printer
578 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
