Question about Singer Sewing Machines
How do i set the tension on a sewing machine but i dont hav a manual model 5816c singer
SOURCE: need manual for Singer sewing machine model#100, about 12 years old
I have a manual for this machine..is there something specific you needed to know from the manual?
Posted on Mar 27, 2008
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
  • 43 Answers
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
Posted on May 06, 2009
SOURCE: Looking for a free download of Singer Sewing Machine 6235
if you still haven't found one, reply to this thread. I have one as a PDF that I just bought for $5 that I'd be willing to share (this goes for anyone who finds this post, too)
Posted on Feb 26, 2010
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
How to thread tension on my L47 singer sewing machine
Threading and tension are two different things.
You can search for a manual:
Make Model manual
or
Make Model threading
(most machines thread similarly so even if you don't find your specific model, the instructions would be helpful)
https://www.manualslib.com/products/Singer-L47-4062252.html
When threading, be sure to ALWAYS RAISE the presser foot so the thread will seat completely in the tension disk.
For tension, generally start with the tension set at the midway point. Tension is correct when the top and bobbin threads meet in the middle of the fabric. If the bobbin thread is showing on the fabric top, loosen the top tension. If the top thread is showing on the underside of the fabric, tighten the top tension. Do not adjust the bobbin tension until it has been determined that the top tension does not make the adjustments needed. (Bobbin tension is sensitive--a little change makes a big affect so you will need to know how to reverse any changes you make.)
Understanding Thread Tension Threads
Jan 15, 2018 | Singer Sewing Machines
Machine is 30+ yrs old and tension settings .. There are 3.. Are all screwed up so stiches are not even, tight or inform...can someone help me know the normal setting and how to adjust for zigzag...
You haven't mentioned a brand or model number. Go to this YouTube page for general repairs and setting up zig zag.
https://www.youtube.com/results?search_query=how+to+adjust+seetings+on+sew+machine+for+zig+zag
But in any event, go to the manufacturer's website and go to the support page. Download the user manual, if they still have them, for your model. Settings should be located within manual.
Mar 04, 2015 | Sewing Machines
The tension is off on my model 3962. What should I do the manual says to set the control know to "auto" it only goes from zero to four and then a black dot. Also what is the dial on the right side of the...
Well, one is the stitch length control (top) and one is the stitch selector (underneath it). I have never seen you machine; I found it out by download the instruction manual free from the Singer site, and you can too. I highly recommend it.
On page 19, it discusses tension settings.
Jun 17, 2014 | Singer 3962 Mechanical Sewing Machine
Singer 3116 tension problem
since the tension is the same no matter where the dial is set, the machine may need a new tension dial.
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number--(example 3116)
Click search
Mar 25, 2012 | Singer 3116 Simple
Where do i fix the tension at? i understand there is a top and bottom but i just dont understand. The thread keeps getting bunched up. It sews good for a bit then it just bunches up and i dont know what...
why dont you visit this website and read up some of the general info on sewing machines, should help you get started.
http://sewing.about.com/od/sewingmachineindex/bb/sewingmachines.htm
Usually you should only need to adjust the top tension a little bit for different fabrics but generally it should be fine on 5. Bottom tension is set by a little screw on the bobbin case (if yours is a removable front loading type) or sometimes a little dial if fixed horizontal bobbin case design. If machine has been set up correctly from new then bottom tension should not need to be touched at all.
It sounds more like your machine is not threaded properly, causing the thread bunching up to occur. If you don't have a manual you may find a threading diagram at www.sewusa.com or www.singerco.com, the Singer website has instruction manuals for download free for many models.
It sounds like you may be a beginner sewer, in which case, I highly recommend taking a few classes to learn how to best utilise your machine and save lots of frustration too.
Jul 07, 2011 | Singer 1507
The machine will sew about three inches then the hook gets several threads around it and stops. I think the timing is off. How to set hook timing on a 2263 Singer Sewing Machine?
You can download an instruction manual for Singer machines from here http://www.singerco.com/accessories/manuals.html, just type in the model number and click "search".
This sounds more like top thread is not in tension though so have you checked tension is working okay?
However, to adjust timing you will need a service manual or general instructions for a horizontal hook sewing machine. You may find a video that helps with this on You-tube, I just leave it to the experts.
May 22, 2011 | Singer 2263 Mechanical Sewing Machine
Looking for sewing machine manual for singer sewing machine model 6218. The bottom bobbin tension is so loose that it forms many loops under the fabric.
I went to the singer website & typed the number in 6218 & it came up with nothing, is that the correct model number?
the tension problem try adjusting the top thread tension to 3-5, & see if that helps the loose tension
Oct 21, 2010 | Singer Sewing Machines
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
122 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
