Question about Xerox WorkCentre 3210 - Multifunction - B/W - laser - copying
Xerox WokCentre 3210 toner When I charge ( farst) toner xerox 3210, he dos not job, and writes TONER EXHUSTED? why?
  • 319 Answers
Web-ngram.research.microsoft.com/.../BingBodyJun09_Top100KWords.txt
Posted on Aug 03, 2010
  • Rick Carter Dec 01, 2010
    I have a Xerxo work centre 3210-when I print configuration report pritn fine but copies and sent print jobs are blurry. Its no the toner because it would have this problem all the time
How can solve xerox 4110 error code 093-311
This code means toner mot fail so check for toner caking after that go mvm location 762-032(write down current val just in case) whatever value ...A Hard reboot might be needed shut it down an turn up after 5 minutes
Oct 04, 2017 | Xerox Office Equipment & Supplies
My scanner xerox 3210 scanner locked and I con't find the unlock switch
It's located where the paper comes out above the toner door. It's on the top side on the left. Put your hand inside where the paper exits on the left side and it's above your hand.
Jun 27, 2016 | Xerox 3210/N WorkCentre series 3210/N MFC...
Would you please tell me how to reset xerox workcentre 3210 cartdridge chip?
Hi Marco,
They have a chip in them and can't be fooled so to speak by topping them up.
You can get toner and chips off ebay if you do a search for your model...
refer to link for an example...
http://www.ebay.com.au/itm/Hi-Yd-Toner-Refill-Reset-Chip-for-Xerox-WorkCentre-3210-3220-106R01487-/261253227411
Oct 26, 2014 | Xerox WorkCentre 3210 - Multifunction -...
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox WorkCentre 3210 invalid toner
Verify you are use OEM Xerox Toner. If so, try reboot the unit, take out and reseat the toner. If that doesn't fix it you'll have a bad main board and will need to be replaced.
Sep 12, 2013 | Xerox WorkCentre 3210 - Multifunction -...
On Xerox Phaser 3100mfp., after refilling the toner its asking "insert toner card"
when you refill the cartridge you got to put a card {seem like a credit card} to reset a counter of the printer. the slot of card is in bottom of control panel {panel with buttons}
Jan 11, 2011 | Xerox Phaser 3100MFP/S Laser Printer
How verify the xerox toner's originality?
OEM Xerox toner will have the Xerox logo on the box. The best way to see if your toner is not original Xerox toner is to look for the words "for use in". If the words "for use in" are on the box it is NOT Xerox toner but a generic or aftermarket version.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 30, 2010 | Xerox Office Equipment & Supplies
Error 9-355 on dc12 xerox
That is a magenta toner empty message, either the magenta cartridge is empty or there is an issue with the magenta toner dispensing.
Nov 14, 2009 | Xerox DocuColor 12 Printer
Xerox WorkCentre 3210 - Multifunction  - B/W - laser - copying  Logo
1,026 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
