Question about Epson Stylus Photo R200 InkJet Printer
I have a epson R200. it tells me the ink is out, I have replaced the cartridge but it still tells me the ink is out. also it seems not to udate the supply level info. any tips? william
  • 319 Answers
Www.fixya.com/postanswer.aspx?thid=5455844&prdid=342982...
Posted on Aug 03, 2010
Epson stylus photo R200 status monitor in Windows 7 is'nt highlighted ink is low can't tell which ones
Uninstall the current driver and Status Monitor, once uninstalled connect and power the printer on to install the Windows 7 In box driver. If that does not work then you can tell which cartridges need replacing using the printer itself. Lift the lid and press the red ink button once. The carriage will move to the left and stop by a pointer. This will point to the cartridge that needs replacing. Repeat until it is in the change and then change the indicated cartridge/s and then press again to complete the change.
Jan 27, 2010 | Epson Stylus Photo R200 InkJet Printer
Epsom photo r200 ink issues
Unfortunately no there is not. However, when those are refilled the kill chips should be reset and the cartridge should function same as new. If you are not getting this result I would not buy ink from that supplier anymore. Cartridge World 100% guarantees their cartridges and will always reset the chips.
Jan 14, 2010 | Epson Stylus Photo R200 InkJet Printer
SSC Service Util for Epson R200
SSC can't reset ink level. Printer read ink level counter in chip, not actually. Use chip with autoreset function.
May 04, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson Photo R200 unrecognised cartridge message
Problem solved! I moved each cartridge up slightly to break contact and then snapped them back into place. Loaded a job up, pressed print and it started with no problem.
Jan 14, 2009 | Epson Stylus Photo R200 InkJet Printer
MY EPSON STYLUS PHOTO R200 HAS THE RED A GREEN LIGHT FLASHING
WWW.EPSON.COM/SUPPORT AND DOWNLOADS, WHEN YOU FLIP OPEN THE COVER SEE IF THE UNDERSIDE HAS A INSTRUCTION APPLET ON CLEANING AND REPLACING INK CARTRIDGES, THOSE LIGHTS MEAN 2- THINGS RED-LIGHT, INK IS TOO LOW,NEEDS REPLACEMENT, RED WITH GREEN AFTER REPLACEMENT CLEAN HEADS, I HAVE SAME PRINTER , NOTHING MAJOR, USER GUIDE IS ON SITE ALSO IN PDF, FORMAT.... JON T
Dec 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson photo r200
Sadly, if only one cartridge is empty, an Epson printer won't print. But, you can bypass that by using a chip re-setter. They have them in refill stores. By using a chip re-setter, you assign a new serial number to your cartridge, thus "fooling" the printer you have put a new cartridge in. Then, you don't need to refill all the cartridges.
Sep 09, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 - print with black ink only
Nope.....
Epson will not print unless all carts have ink in them to some degree. If the light is on for any reason, printing will be halted.
For future reference, once the color carts have been replaced, you can set the printing defaults to print in either gray scale or BW only. Keep in mind that Epson printers tend to mess up if you don't use the ink at least once a week.
Aug 01, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson r200
Have you have refilled your cartridge, have you ressetted the memory ?
Mar 15, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson photo r200 will not print
so after reseating all the cartridges and doing head cleaning from the computer / driver and still not getting any output on the paper :
if it´s not the printer - hopefully it´s the ink
have them replaced, contact the manufacturer
Dec 23, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson r200
turn off and disconnect from computer.
load plain paper.
press and hold paper feed button WHILE turning the printer on.
still no ink on the paper with new genuine cartridge ?
contact manufacturer for repair.
Dec 17, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
254 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
