Question about GE Wireless Optical Mouse
GE Mini Mouse 98563
Bought this mouse new yesterday.Hooked it up and it worked fine.Suddenly stopped working.Tried the connect button on mouse,will not connect.Driver is up to date,Have unplugged the USB receiver and restarted computer,still will not work.How can I get it to work again.Batteries are new.
Hi, I had the same problem. The USB device has what appears to be a circle with dots connected to it facing the port. The dots are actually the word "Connect" in infintessimally small letters. Plug it in, then use your thumb to press down on the circle while using another finger to press up on the device's underside - in effect, squeeze it between your fingers where the circle is. You'll see a red light blink. At that point you can push the "connect" button on your mouse and it will work.
Posted on Nov 05, 2010
  • psosborne Dec 23, 2010
    Thanks for the help...I spent a couple of hours trying to rememdy this issue, and even loaded my old mouse with new batteries, with the intent of taking this device back to the vendor...It works fine now...
    Phil O.
I had the same problem until I read in the instruction book that you also have to press the "button" on the USB receiver, then it began working fine. Hope this helps!
Posted on Sep 25, 2010
I have a ge 98563 ergonomic wireless mini mouse and my laptop wont recognize it
I have had no problems with my compaq laptop and the mini mouse. It recognized it even after OS downgrade to XP. The reset buttons on the mouse and the transceiver need to be activated or reset when sitting idle for a while. Once you get them both "blinking" it works great. Good mouse for the price... Your laptop should recognize it. Just check the reset and make sure the lites are on and communicating.
Nov 21, 2010 | GE Wireless Optical Mouse
I have a GE wireless mouse = 98563, bought about 2 weeks ago and have used it only a couple of times however recently i have developed problems with it, I bought a new pack of triple As and even then the...
1. Go to manufacturer's website and download the driver for the correct MODEL of the mouse.
2. Install mouse driver. Go "Control Panel" to configure mouse software.
3. o/s XP, right mouse click "My Computer" go Properties, Hardware tab, Device Manager, scroll down to "Mice and other Pointing Devices" to see if it is registered, and also check "USB Human Interface Device" in the same window to see if your usb connections are functioning. There should be NO YELLOW question marks in this window pertaining to USB and Mice Pointing Devices.
If it was a wired mouse with no name or model, you can just plug it into the ports and it will work. Unfortunately, since it is wireless, you MUST have the correct drivers(software that allows your computer to communicate with the device), and the only way you can get the correct drivers is through the manufacturer and choose the right model.
ALSO
Nov 20, 2010 | GE Wireless Optical Mouse
I have hooked up a GE 98548 wireless mini optical mouse. It worked the first time I tried it, but later would not work at all. What's next?
on the receiver there is a a little circle with the words connect around it. Its actually a button you press that and you should see the receiver should light up make sure the receiver is connected the computer and press down right on the circle. after it lights up press connect button on the mouse and it should start working again
Jul 02, 2010 | GE Wireless Optical Mouse
GE wireless optical mouse suddenly stopped working. i restarted computer and tried to reset both mouse and the receiver to no avail. also changed out batteries.
Hi, my mouse work fine since pressed simultaneously the buttons of the mouse and the receiver. Previously, I had disarm the receiver, but all was fine, so I'd arm again the receiver and plug to laptop; I'd press both buttons and mouse work. For any reasson, mouse and receiver lost conection and is necessary re-establish comunication pressed both buttons. I hope my experience (my case) to be useful to someone.
Jun 24, 2010 | GE Wireless Optical Mouse
Logitech Mouse V320 Corless Optical Mouse not working
The warrenty period is usually a year. Is there a connection button on the receiver as well? Normally you need to press the connect button on the mouse, and then on the receiver shortly there after. If you want to replace it, you might have an easier time just getting a new mouse.
Jan 25, 2009 | Logitech Cordless Mouse
Vx problem:movement
First try this
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
If that doesn't do it theen try this.
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 30, 2008 | Logitech VX Revolution 931690-0403 Mouse
Wireless key board
Have you tried re-setting the frequency for one of the devices? simply click the button on the infra-red unit then click the button on the back of keyboard and notice the infra-red unit stopped scanning.
Oct 23, 2007 | Logitech Cordless Desktop EX110
GE Wireless Optical Mouse Logo
2,699 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
