Question about GE 24 in. Profile PDW9200J Built-in Dishwasher
I have a ge max dishwater that isnt draining - GE 24 in. Profile PDW9200J Built-in Dishwasher
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasheri have a ge max - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Aug 03, 2010
Dishwater goes from sink to bottom of dishwater
you need to tie up the drain hose under the sink above where it connects to the drain spigot to stop the sink water flowing down into dishwasher instead of the drain. A blockage in the sink drainage can also make the condition worse.
Jul 14, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwater not fully exspeeling from dishwaser
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning FREELY. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Mar 26, 2010 | GE Nautilus 24" Built-in Dishwasher
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
If dishwater is draining slowly on our GE Dishwasher, how do we fix?
The flapper in the drain pump is broken off and blocking the outlet.
Jun 27, 2009 | Dishwashers
GE WSSH300G0WW will not drain
this means the machine isnt spinning fast enough, or the drains are clogged.
Apr 29, 2009 | GE WSXH208A Front Load Washer
Dishwasher did not drain out all of the water
run it again on the hot cycle...if that doesn't work...you have a clogged drain hose or a defective pump.
Apr 04, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Drains slowly
could be pump bad!? when you disconnected under ...gravity took over
Mar 15, 2009 | GE GSD5610D Dishwasher
Ge dishwater problem
glasses have a film that wont wash or rub off
Mar 11, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE 24 in. Profile PDW9200J Built-in Dishwasher Logo
282 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
