Question about Stairmaster 4400 PT Stair Stepper
My stairmaster has begun to squeak or chirp. It gets louder at higher resistance levels. Moving parts that I can see have been lubricated. Any ideas? Thanks!
  • Stairmaster Master
  • 918 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This sounds like either an alternator issue or the brushes in the alternator. I am going to attach some troubleshooting videos.
Stairmaster Stepper 4400PT Parts Chain Pedal Arm Fastener SPORTSMITH net
Posted on Oct 05, 2015
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: My Stairmaster 4600CL is stuck
What has happened is the control panel is bad and you need to replace it.
Good Luck
Posted on Jan 07, 2011
Dehumidifier squeaks when running
Disconnect it, (DO NOT REPAIR WHILE CONNECTED), remove outer plastic casing (screws), lubricate moving parts with a little WD40 or similar. Re-assemble.
If you can get to the part that's squeaking with a long tube you could try spraying silicone lubricant spray on it without disassembling.
Apr 03, 2014 | Dehumidifiers
Mazda protege makes a squeaking noise when I start driving?
If your Mazda Tribute's engine has a rumbling noise when you start it, this is most likely from the drive belt. You will need to replace it.
May 30, 2013 | Mazda Protege Cars & Trucks
My Stairmaster 7000PT has no resistance past level 10 or 11?
This could be caused by worn alternator brushes. The following link will take you to a video on testing the alternator. If the alternator checks out, you may be dealing with a faulty display console.
Video about Performing Jumper Test on Stairmaster Alternator
Feb 06, 2013 | Stairmaster Stepmill 7000 Pt
Stepmill has no resistance when starting
First thing you'll want to do is check the alternator brushes. Here's a link to the different types offered for the Stairmaster 7000PT:
Repair Parts for Stairmaster Equipment Batteries Springs Belts Chains...
If the brushes look like they are in good condition you can also test the relay board. This link will take you to the procedures for checking the relay board:
Stairmaster Stepmill 7000PT Electronic Testing of Relay Board
Nov 06, 2012 | Stairmaster Stepmill 7000 Pt
Its a chirping or squeaking noise and gets louder when gas is acclerated
Belt tensioner has a bearing and your belt rides on it and its bad, call parts store for price.
Mar 16, 2011 | Chevrolet Venture Cars & Trucks
Hey, just purchased some behringer ms 40 near field monitors and after a few hours of playing at around the 1/4 volume mark i decided to turn the bass up. As i did so the right monitor began to make a...
The setting of the volume controls bears LITTLE importance to the actual level the unit is being run at since one can send high levels INTO the units from the source. These are intended to be used in a studio for the audio engineer to listen to in a small room. They should really be no louder than a consumer BoomBox maximum.
A squeaking noise is not normal at a level such as mentioned however. You might see if the noise is from the speaker itself or possibly parts of the cabinet... Plastic parts are NOTED for squeeking and can be suitably lubricated.
Beyond that, since the units are new, you should be able to exercise your warranty.
Mar 10, 2011 | Behringer Ms40 40w Active Powered Studio...
My dryer squeaks
First you should try to determine what the squeak is related to, does it happen every time the drum rotates or more frequently. This will give you some idea of where to look. You should disconnect it , take off the top and get someone to rotate the drum by hand while you listen. Moving parts are dangerous don't put fingers in. Commonly the outer drum bearing or belt idler need lubrication. Don't lubricate the belt. More details if you provide more clues.
Jan 13, 2011 | Frigidaire Dryers
Hi, the sustain pedal on my Casio PX-830 has a constant squeak now after 6 months, any ideas on a fix for this? Thanks.
clean with q-tips and rubbing alcohol around the moving parts, let dry 5 min, and some graphite lubricant may help. graphite is a slippery dry powder good for reducing friction on moving parts. comes in a little tube, normally sold buy the key making dept at any store
Dec 21, 2010 | Casio PX-830 BK Privia
2005 chevy Impala brakes sqeak loudly
You brakes are no longer any good. Most times, the squeaking and rubbing noises are caused by brake pad wear, but you say the brakes are fine. Otherwise, if by constant rotation speed you mean the squeaking/rubbing noise is present even when the brakes are not applied, you might want to get the wheel bearing inspected.
also check out -------- The most common would be a loose P/S belt. If it is tight but is still the source, it could be a restriction in the P/S system causing high pressure and resistance in the pump.
Mar 07, 2009 | 2005 Chevrolet Impala
Stairmaster 4400 PT Stair Stepper Logo
753 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
