Question about Bosch SHU5315UC Dishwasher
Not cleaning properly and making a buzzing noise after it fills?
  • Bosch Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
Samsung dishwasher makes a loud buzzing sound when the water is filling. It pulses a couple times to start then is constant. It pulses again right before the wash cycle. Comes from the bottom left.
This is common. The noise is coming from the water pump. If it bothers you, you can try UNPLUGGING the washer or turn off the Circuit breaker first. Then you can remove the bottom kickplate on the front of the washer and clean around the pump. If there is a water filter scree, clean it out. Make sure there is nothing rubbing against the pump which could cause a buzz. Tighten all fittings and screws to eliminate vibration noise.
Aug 30, 2015 | Samsung Dishwashers
When u start it it just make a buzzing noise but doesnt fill with water
Hi, if there's no water at all, make these checks:
Is there water getting to the machine?
Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 13, 2011 | Washing Machines
It keeps stopping flashing LF,I don't have the manual,what does LF mean?
Hello there:
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. furthermore please check the following that may apply
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
Aug 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Makes a buzzing noise,no cooling
buzzing noise is prob/ the evap fan . ck that both evap fan and cond fan re working .. . and clean the coils underneath .. .mm
Jul 04, 2010 | Frigidaire FRT21P5A Top Freezer...
Why is my dishwasher making a buzzing noise? It is almost 2 years old and is a GE brand we got from Sears. It is still cleaning and filling and emptying properly, but the buzzing noise is driving me...
Sounds like a noisy circulation pump motor. As an Engineer, I would treat any abnormal noise seriously; the motor may require examination and possibly a new start capacitor fitting? or it may be loose or have a problem with its impeller, etc. Or it could possibly be a relay for the heating element is noisy. Either way, abnormal noises are unusual, and dishwashers need to be 100% reliable as they are often used unattended or overnight and any problem might indicate a possible fire risk. Sorry to be so heavy - is the machine subject to any guarantees or extended insurance etc? Some have 5 year guarantees. Whatever, I would call an engineer out to have it checked over.
Feb 02, 2018 | Jenn-Air JDB6510 Built-in Dishwasher
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
I have a candy cic60 reverse action condenser dryer about six years old.when it is switched on i makes a buzzing noise and nothing happens apart from the buzzing,any ideas
my candy dryer when on the light keeps come on to clean fliter and the water contain dont seem to being filling up with water
Jul 07, 2009 | Candy CDC266 Dryer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Bosch SHU5315UC Dishwasher Logo
90 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
