Motor Efka AB62CV1466 is set on sewing machine Juki DDL 555-4. When turned on the motor does not run when the sewing machine peddle is pressed and sends the signal E3. Please tell me what to do. e-mail. I will appreciate your help. I will hope that they will have a service center. Sincerely Benito. benitogonsalves@yahoo.com
sodeep
  • 3267 Answers
SOURCE: Hello,
Visit this link :
http://support.asus.com/download/download.aspx?modelname=P5GZ-MX&SLanguage=en-us
select your OS and download the required driver......sodeep
Posted on Apr 07, 2009
Zenqi
  • 208 Answers
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Posted on Jun 17, 2009
SOURCE: Needle not catching thread
im no expert, just been sewing for many years, i use 2 different juki machines, i suggest looking at the needle, are we sure you have the rite size? 135/ 140? did the needle just get changed? it could be the correct one, but if its in backwards, there isn't a dimple to let the hook behind the thread, to catch it, feel free to call me, 239-895-4845, my name is devin, shop is Quality Auto Trim Inc., ill try to help you over the phone if necessary, good luck
Posted on Mar 12, 2010
SOURCE: how to fix timing on a juki ddl-555
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Posted on Apr 23, 2010
SOURCE: what is the address for intel motherboard service
U just write Google page *********** board name & model, than u found.
Posted on Jul 13, 2010
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
Error code E3 45786 on Juki sewing machine motor
I could not find that error using the Manual that is on the Internet.
I suggest you call or email their Sales and Service in the U.K.
Their email is sew-europe@btconnect.com
JUKI DDL 5530 DDL 5550 Parts Needles Service
Feb 16, 2015 | Juki DDL-5550 Industrial Straight Stitch...
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
My juki industral sewing machine has started to make a moaning noise when i press the foot peddle . what would cause this?
hi there,there's many reasons :1- check belt tension is it OK or to much loose?2- check if there's some heating between belt and belt cover.3- check clutch break inside motor maybe need to change.best regards
Jan 26, 2012 | Juki DDL-8300
What type of oil is need fro juki ddl-555
hi there
you can use juki deffrix oil no.1 or in your local market light and clear oil for industerial sewing machine
May 22, 2010 | Juki DDL-8300
Is there a simple way to slow the speed down on a Juki DDL-8700??? My friend wants to sew, but it is way too fast for her .........any help would be appreciated.
On the motor where the clutch is you will see thge large pin with a nut on it, as you press on the pedal the pin engages with the motor, if you loosen the nut and unscrew the pin bit by bit and try the machine you will get to a point where you will have absolute control on the speed.
Nov 05, 2009 | Juki DDL-8700
How to fix timing on a juki ddl-555 sewing machine
Sep 14, 2009 | Juki DDL-8300
Jun 17, 2009 | Juki MO-644D Mechanical Sewing Machine
Computers & Internet Logo
575 people viewed this question
Alun Cox
David Payne
David Payne
