Question about Whirlpool LER4634J Electric Dryer
I have a Whirlpool LER4634J Electric Dryer that has stopped mid-cycle and will not restart. I know VERY LITTLE about dryers so please use plain language if you give suggestions about how to fix it. Thanks!
1. Does it have electric power? Is the breaker or fuse good? Is the power plug loose?
2. Is the door to the dryer ajar? Please open and close it a few times to check this.
If this doesn't help, you may need new or repaired parts. The timer motor that turns the dryer switch may have failed. The clutch that allows you to turn the select knob for the different dryer cycles may be slipping and have failed. The start button that begins the dryer cycle may have failed after a temporary power outage. The door switch may have failed. The particular switch in the dryer cycle setting you are using may have failed (Other cycles may still work). The dryer thermostat(s) may have failed (prevents too hot/ over-heating). Follow the wires from the "heat selection switch" to find thermostat(s) in the hot air duct. They "turn ON" when too cool and "turn OFF" when hot enough. Mechanical switch contacts can "melt together" and stay always ON. Or switches can get pitted and stay "always OFF" after enough ON/OFF cycles. If pitted contacts happen, you can see this on them. Sometimes a finger nail file (I do not recommend a metal one) can shine them up again. Solid state (electronic) switches have to be tested with a meter or something else to see failure. Please don't do work on electrical or any other problems while the dryer is plugged in or still hot. Good luck. Your mileage may vary. ;-)
Posted on Aug 23, 2010
Whirlpool Supreme Dryer rumbles while turned on then stops mid cycle. When I push the start button I hear a buzzing noise, then a click and then silence. After the dryer sits for a while, it will start...
Chances are it's the drive that drives the belt around the drum, or the motor is on its way out. Have a technician inspect the belt/belt drive system as well as the motor.
Jan 29, 2010 | Whirlpool LER4634J Electric Dryer
Dryer stopped, will not restart. Overheated.
you need chek :
1-bushin motor
2-bushin drum.
Oct 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Mod LER4634JQ0 has stopped working - you can hear the timer clicking, but does not operate on any cycles
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Whirlpool LER4634J Electric Dryer
Dryer overheats, stops mid-cycle
Hi, Will the dryer restart right away? Sounds like a motor going bad. With a model #, I can get you part#s if you need them. Is this a whirlpool brand?
Let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Dryers
Whirlpool gas dryer stops in mid cycle and then starts up again
make sure of mode# make inside door and I will help you. also how old is your drier?
Feb 01, 2009 | Whirlpool LER4634J Electric Dryer
That timer can be purchaced on servicerepairparts.com http://www.applianceaid.com/refrigerator.html#freezing
They offer great advice how to and my free advice. Timer is not hard to replace if you want my help I have time to answer any request, Let me know
Jan 29, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
