Question about Kenmore Elite 20972
Remove Doors on Side by Side Kenmore Elite Refrigerator with water tube
I need to remove the doors of my Kenmore Elite side-by-side refrigerator. There is a water feed tube going into the door from the the bottom. There is also a connector that allows the tube from the door to connect to the supply line going under the refrigerator.
My question is how do I disconnect the tube so I can remove the door?
Tom
    Genius:
  • 1,073 Answers
This is the new style connectors push in on the blue end of the connector and pull on the hose it will come out of the quick connect connector
Posted on Apr 25, 2008
I had the same problem, it took me an hour. The connector allowing the tube from the door is connected to the back of the refrigerator. You must go to the back and unhook the white tube from the connector, then it will easily come off the refrigerators door. Hopefully it works for you.
Posted on Jul 26, 2009
Kenmore Elite refrigerator icemaker wont fill with water to make ice.
The water feed tube may be frozen. If you can see it you can try to defrost it with a hairdryer to allow the water to pass again.
Oct 17, 2013 | Refrigerators
Kenmore refridgerater
HI. STEVE.most pipes have a connector under the bottom cover.disconnect and feed through the inside of door after removing front cover of the dispenser.good luck ali.
Jun 21, 2012 | Kenmore Side by Side Refrigerator
Replace door water dispenser plastic tubing
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
May 30, 2012 | Kenmore Side by Side Refrigerator
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite (795.75544401)is suddenly dripping water from the bottom of left french door.
Hello and Welcome to FixYa!
The dripping water could be from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit.... The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. Another cause may be the refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something like that, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the water disappears the problem is solved.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 18, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
Kenmore side by side: ice maker works...ice
Probably a broken plastic tube from the solenoid valve to the water outlet tube. It will stay dry until you try to get water then it may take a few days to dry out.
Good Luck,
Gilsh
Nov 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Tubing leaking in refrigerator door
if your talking about the water line fron the bottom ofthe door to the dispensor head, it pulls out and is replaceable, might be a little tricke to feed through the door but ther is a channel in which it will push back through
Nov 15, 2008 | Frigidaire FRS26R4A Side by Side...
Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Oct 19, 2007 | Kenmore 57029 Side by Side Refrigerator
Washing Machines Logo
3,072 people viewed this question
Sal De
fordexpert
Robert Rankin
