Mac air does not boot, I just see the apple logo and the spinning gear wheel
  • 319 Answers
Forums.macrumors.com/showthread.php?t=882285
Posted on Aug 03, 2010
Lost power when changing computer name and key. no boot or sys disk. boots to apple logo and spin wheel. how to recover w/o loss of data
Try holding down the option key (ALT) when you boot up and see if you can see your startup disk. Good luck....
May 22, 2016 | Apple PowerBook G4 Mac Notebook
My macbook white fell on the floor and now I only get the apple logo with spinning wheel and time bar. I have waited more then 15 minutes but no changes. I do not have the disk. I have tired safe boot,...
The time bar may be telling you that there's damage to the hard drive, or perhaps just your hard drive's main partition.
If your Mac is running OS X Lion or Mountain Lion, you should have a recovery partition with Disk Utility on it. Restart your Mac while holding down Command-R to boot into this instead of your regular partition. Follow Apple's instructions on how to use Disk Utility to see whether the hard drive is damaged or just corrupted (and potentially corrupted).
Sep 06, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My Macbook pro turns on but then gets stuck at the Apple logo with the loading gear and never finishes loading.
See if you can start your Mac in safe mode:
Shut down your Mac and wait 10 seconds.
  1. Press the power button.
  2. Immediately after you hear the startup tone, hold down the Shift key. You should press the Shift key as soon as possible after you hear the startup tone, but not before.
  3. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
To leave safe mode, restart your Mac normally without holding down any keys during startup.
If you can boot in safe mode, you have something on board your computer that's interfering with startup. If you've recently installed software, system extensions or 3rd party preference panels (Adobe and Microsoft stuff is notorious), try to disable or de-install it. If you can't get booted in safe mode, you may have a hardware or memory problem that might require technical repair. Repost your progress.
Apr 05, 2013 | Apple 13.3 MacBook Pro Notebook Computer ...
I have a macbook air, and i turned it on today and the white screen appeared on the screen with the apple logo, then the wheel started spinning for hours and it doesnt turn on, i wonder how can i fix it?...
Find you apple install CD's and choose the one that says application install. as you turn in on try and put the CD in and hold down the D key this should run the disk before start up and allow you to run a hardware check.
Aug 14, 2011 | Apple MacBook Air
My apple macbook air will not reboot. it turns on but does not reboot completely then it shuts down and tries to reboot again and again. apple logo appears and the spinning icon rotates but never goes...
It may be a possibility that the hard drive has gone bad or a connection to the hard drive. The spinning wheel and apple signify the kernel boot, or in other words, the process in which the machine finds the hd and os/software.. you need to bring your machine into an authorized repair center to have a system diagnosis to verify that no other parts of the machine are bad. That model is notorious for having bad hd's.
Nov 24, 2010 | Apple MacBook Air
My G5 won't boot past the gray sreen with the apple logo and time wheel.
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica}
Trying booting from the Mac OS X install disc.
insert the Mac OS X install disc.
press the start button while holding down the "C" key on the keyboard
If it boots normally from the disc. you have a bad hard drive and it will need to be replaced.
Sep 07, 2010 | Apple Power Mac G5 Desktop
Help with my macbook air, it shows only the apple logo and a spinning wheel
Power the machine down. Press the power button to turn it on. After you hear the startup chime, press and hold the shift key. This will trigger an extended file system check and a safe boot. Continue holding the shift key down until you see the spinner, then you can release it. If it doesn't boot completely after this, you will have to bring it in to an Apple-certified tech for repair.
Apr 01, 2010 | Apple MacBook Air
My mac book air doesn´t start, only the apple logo and the beachball spinning after restart
probably the operating system is corrupted . Try to boot with installation media and repair the disk permission and restart the computer.If it boot after file permission repair then its fine or else you have to format it.
Mar 13, 2010 | Apple MacBook Air
Mac book only shows apple logo when turned on
This could be an issue where you may have a few Startup items in your StartupItems folder in your System Library which may be affecting your Macbook's startup.
So I recommend you boot your Mac into Safe Mode to see if you can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
-SAFE BOOT MODE-
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while.
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
Let me know if this helps!
Regards,
-Mactechtrainer
Jan 28, 2010 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
293 people viewed this question
Alun Cox
David Payne
David Payne
