Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
I have an Amana AFD2535DEW. It is over a year old but the top has quit cooling, but the freezer is OK. It did this before, but I was told to let it sit over night with out opeing it. That seemed to solve the problem. It is now 2 months later and it has done it again and letting it sit over night did not help, also the center bar on the door (the one that pivots to seal the doors) is hot. Should I call for a repair?
Mine did the same thing about two years ago. It turned out, my problem was the little motor that opens the vent in the refrig portion to let the cold air in from the freezer went bad. A&E service tech said this was common. Cost about $90 to fix. Haven't had the problem anymore.
Posted on Feb 26, 2011
Repairing freezer drawer slides on amana afd2535dew
if gear wheels are out of sink, give it a good twist till equil.
ifb it is the ballbearings in the rails replace hole rail, wize to do both sides at one time.
Apr 07, 2014 | Amana AFD2535DEW 25 french door bm...
My Amana 26 cu ft side by side quit cooling entirely in the freezer and the refrigerator. Is it worth it to get a repairman or should we just get a new frig. This one is 6 years old
I suggest get help with repairman.6 year old is not very old.Refrigerators have life more then 8 to 10 years.The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Oct 24, 2011 | Amana 26 cu. ft. Side-By-Side...
Amana BRF 20. I know there is a problem when the fridge part is getting warm. The first time, we called a technician and he told us that we had ice build up in the bottom freezer part, at the back of the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Defrost timer/control board is bad...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 14, 2010 | Refrigerators
I have an Amana side by side model ARS2664BW. The unit is about 8 years old. The water dispenser on the freezer door quit working and the cooling units inside the freezer and frig are not working proper....
I did a search on Amana.com's knowledge base and didn't find anything useful regarding your two top cooling units not working.
At amana.com, I tried to download the manual, but the service was unavailable until 8/9/2010 after 8:00AM due to system upgrades.
http://www.servicebench.com/servlet/WebSideServlet?Request_Id=APPWhirlpoolDealerLocateBrandedGoto&Request_Server=servicebenchpublic&Request_Brand=L1&Request_ReadUrl=Y
The above is a service locator for your refrigerator. Since their site doesn't seem to have a solution for this, I would call in the pros if you want to have it fixed more quickly than trying to do it yourself.
Aug 07, 2010 | Amana ARS2464B Side by Side Refrigerator
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
I have an amana arb2557csl top fridge that quit working today. yestarday was fine today hot. no noises that i am aware of. it is around 5 and 1/2 years old. can i fix it without paying a fortune? what...
you have a good brand . back to problem ck for ice on back wall of freezer if so you have a defrost problem and coil is blocked with ice . if no ice make sure the fan inside and down under neath are working and clean the coil. all of these will prevent the unit from cooling .. hope this helped mm
Jul 03, 2010 | Amana ARB2557CSR / ARB2557CSL Bottom...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
My Amana AFD2535DEW freezer problem
Sound like the compressor is having trouble starting. You can purchase a RCO810 to assist the compressor's start winding. If the unit is under 5yrs there should be some warranty (no electrical parts) left in the compressor. It will need to be replaced.
Oct 16, 2007 | Amana AFD2535DES French Door Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
121 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
