Question about Sharp EL-1801P Calculator
Cant get new paper roll in the machine paper rol ran out
  • 3 Answers
Try a bit harder
becarfull not to break it
Posted on Aug 03, 2010
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
Rheem Spa heater -- getting ROL error??
ROL is for a roll out switch check to make sure nothing is obstructing flue.
Apr 30, 2011 | Heating & Cooling
I ran out of paper and purchased a new roll of paper. I do not know how to install the new roll of paper.
Just drop in, the paper needs to come toward you from the bottom and just past the paper cover once closed. If you have a paper roll spindle, insert and line up with the spindle guides on the machine.
Mar 20, 2009 | VeriFone Omni 3200 Printer
Can i insert Two different coloureds Tag Rols in the Machine
If you put 2 rolls in, the labels will float around, since there is no way to keep each loose end in place.
Dec 23, 2008 | Zebra Z4Mplus Label Printer
Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Help, cant use it !!
The roll of thermal paper can print only on 1 side. make sure the roll of paper is in correctly.
Jan 20, 2008 | Philips PPF-531 Plain Paper Thermal...
Paper not moving forward
please confirm that nothing droped inside in your printer (pins-stapler-small pieces of torn paper)-double a piece of paper roll and try to insert it while you press paper feed button to remove any object in paper path- apply light grease in gears and test your calculator.if the problem exist pass it to service center.
Sep 18, 2007 | Sharp EL-2630P Calculator
Sharp EL-1801P Calculator Logo
169 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
