Question about Mitsubishi WD-52631 52" Projection HDTV
Ihave a lockout on chanel 3 and dont know the code
Go to this web site & download the user manual.
http://www.mitsubishi-tv.com/support.html
Posted on Aug 03, 2010
Chanel button changes input
Try 124 code, might work for combo unit.
Aug 19, 2012 | Innovage Jumbo Remote Control
Ihave Bushldc 26" T.V. and
The most common cause of that is signal break up causing firstly "blocking" of the picture and audio drop out. Heavy clouds can also cause signal deteriation as does heavy rain.
Hope that helps.
Jan 18, 2011 | Televison & Video
It says connect to pc to transfer chanel. dont
I want to be able eliminate like files or songs of mp3 e50 sansa
Jun 02, 2010 | SanDisk Sansa e250 MP3 Player
L/o on the screen only picking up 1 chanel
Do you have frequencies programmed into the other channels? Use the MANUAL key to advance through the channels. If each shows a frequency of 000.0000, you need to program the scanner. It will automatically show LOCKOUT for each unprogrammed (000.0000) channel.
Bill B
May 10, 2010 | Uniden BC60XLT Handheld Scanner
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
No Center Channel on STR-DA5200ES
Da 5200es. Workiig only two Chanel i need five chanel. ihave no remot
Aug 04, 2009 | Sony STR-DA5200ES Receiver
Cant get all of my channels
I LOST MY BOOK HOW DO I PROGRAM MY RECEIVER
Feb 18, 2009 | Motorola DCP-501 Receiver
Dont have remote
well if you still have the manuel for the dvd player the remote codes could be in there. if not you can always call sony tech support and see if they have the code on hand.
Aug 22, 2008 | Hisense TC24FS2H TV
Ihave a hdr1600t i want some help to record one chanel and at the same time how to record the 2nd chanel. please send us easy to understand information thank you
1. Just tune to the 2nd channel you like and press red (record) button. You'll see rec sign on top left.
Do not move to other channel.
2. Press List and scroll up and down to select the record in the list and press OK.
Aug 01, 2008 | Televison & Video
Mitsubishi WD-52631 52" Projection HDTV Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
