New computer won't detect 2wire modem - Computers & Internet
    Scholar:
  • 154 Answers
Probably you need a driver that came with the modem or you have to adjust settings for wireless support / detection.
Posted on Apr 25, 2008
I have moved to new home. I am using 2wire wifi
you can check if the ethercable is loose or if you have a spare ethernet cable (rj45) you can replace the one that youre using
Jul 14, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Need 2700HG-B Drivers!
Try the following:
To access the System Summary page of your Router:
1. Open a Web browser and access the modem gateways user interface by entering http://gateway.2wire.net.
2. Click the System tab to open the System Summary page.
3. Either select
  • Run System Setup Wizard (to install your modem) OR
  • View available upgrades and options (to upgrade the software on your computer to the latest version.
If you do not have a manual for this modem, then click the link below and download it to your computer.
http://support.2wire.com/index.php?page=download
I hope this helps. Please rate. Regards,
Feb 16, 2010 | 2wire 2700HG-B Router (2700HGB)
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Jan 05, 2010 | 2wire HomePortal 1800HG Router...
I received a new 2wire 2701HG-B modem router for AT&T DSL (replacing an older 2wire that burned out) and was able to hook up laptops right away no problem, but desktop doesnt recognize new modem how do...
are you on windows XP, Vista, MAC ???
you start out by seeing if you can ping the 2wire. The ip address you ping from a command prompt is the 2wire's gateway, 192.168.1.254
(you can get to the command prompt by clicking start, then click run, and type cmd and click ok on windows XP)
(on vista, you just click start and type cmd right above it where it says start search and hit enter on your keyboard)
(MAC's have a ping utility located by clicking on the harddrive, applications, network, network utility, and then the ping tab)
a little black window pops open, thats your command prompt
type ping 192.168.1.254 and hit enter on your keyboard
if you dont get replies, then your computer doesn't see the 2wire.
call tech support at 877-722-3755 24/7 for further support if required. We can make sure you nic is config properly, working properly, your not being blocked by a firewall, etc.
Sep 13, 2009 | 2wire 2700HG-B Router (2700HGB)
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
192.168.1.254
255.255.255.0
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
I just bought a SpeedStream 4100 modem
if you brought the wireless new from a vendor. you don't need to configure it. unless you want to.
but if you brought a used one (in you case). you have to configure it. You need to get inside (software wise) of the modem. to do that you need login name and password to start with. if you don't have it, please call or e-mail the guy you brought the modem from.
then you have to configure the security for the wireless, unless you want everyone under sun to access your modem via wireless.
search on the web, you should come away with a user manual for the unit.
Sep 09, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Modem drivers for my PC.....(i can't get online..this is a laptop rt nw)
if you have installed new os, most probably XP can detect the modem, all you got to so is got to modem in your control panel and have a look if its there.
Jun 26, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Home portal not yet activated
XP is an very good OS which will connect with 2wire without any problem.
If your computer is not able to detect modem, pls follow these steps.
* Check for damage of ethernet cable
* Try to reset the modem by using a paper clip punching into the reset button
* Even if your modem is not detected, force the IP and Default gateway
Take care
Feb 26, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
