Question about LG Washing Machines
My lg tromm model number mw2277hw door is hard to shut and is leaking.
    Novelist:
  • 127 Answers
More likely than not the "boot" or rubber seal between the inner tub and the outer door has torn or gotten pulled out of place causing you the interference and resistance when you try to close it. it will also cause a leak if it is torn or badly out of shape. they can be pretty pricey, but only about an hour or less to change on ur own.
Posted on Aug 03, 2010
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
Jan 27, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
STARTING PROBLEM OF FRONTLOAD WASHINGMACHINE
If the error code is DE, then you need the door lock assembly.
I will need the full model number to find the right part number.
Mar 13, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WD R8012 Owners manual
GO TO THIS SITE AND LOOK FOR YOUR MODEL NUMBER UNDER WASHERS. http://www.lge.com/us/support/product/support-product.jsp GOOD LUCK.
Jun 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm LG Washer
On my LG TROMM model # WM1814CW, the door pops open a bit so that water leaks out onto the floor. Is it a simple repair or is it time to get soaked by a repairman. I'm fairly handy, but I don't know if it is an electrical issue or it is a mechanical issue. If you have a suggestion, send it to repihl@yahoo.com.
Thank you,
Bob
Dec 24, 2007 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
83 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
